What headers should I use?
Car: 1989 Camaro z28
Engine: 5.7 350
Hi. I have an 89 camaro RS and I'm wanting to put headers on my 5.7 TBI. The headers i bought are dynomax blackjack black painted headers. The only thing is that they say they work on camaros up till 1981. will they fit or should I look at shorties? Also These headers come with a factory made dent in one of the exhaust tubes for spark plug clearance. I'm also thinking about hooker headers. I wanna spend less than 300 bucks so any help would be great
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: What headers should I use?
second gen headers will not work.
for less then 300, look at hedmen or hooker shorties + Y
Transmission: 4L80E/4L80E
Hooker 2460HKR shorties, $160. Y-pipe, $240. Oops, budget busted. Not a very good y-pipe, either. Eliminates A.I.R., cat. Probably okay for a stock LO3, though. But not emissions-legal.
Hedman 68470 shorties, $150. Y-pipe, $100. Eliminates A.I.R. Meets budget, but not a very good y-pipe. Probably okay for a stock LO3, though. But not emissions-legal.
Engine: 5.7 350
I am removing the A.I.R. because they only use the tail sniffer where I live for inspection and visual inspection of cat. They don't go under the hood.
I've been reading of people using longtube headers on their camaros in the other exhaust sections so I know it's possible.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
The full lengths are not a good choice if you do not want to do any real work, i have used the hooker super comps and the headmans, full lengths, the headmans require some modification ot the drive side a arm mount, the hookers require both sides. Headman shortys and Y pipe are great.
Car: '02 Z06
Engine: L33 5.7
i didnt mention long tubes cuz I know it would exceed your budget. unless you fab your own Y pipe.
redformula88
Oct 14, 2015 06:08 PM
