How find exhaust leak??
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: How find exhaust leak??
Put the car on jack stands, start it up, plug up the tailpipes (rags), and use your hands to feel all along the exhaust (don't burn yourself) for the leaking air or you can usually hear it.
stick your head under there and listen
it helps if you put a long tube up to your ear like a vaccuum extension that helps you pin point it
Last edited by mesterz2889; Jul 10, 2008 at 02:43 PM. Reason: Automerged Doublepost
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
How do you find a leak in a tire? Submerge it in water!
I would guess that you would get the same results with an exhaust leak... maybe try the local boat launch?
just kidding. But really the other 2 suggestions are good.
