exhaust question
Old Jul 10, 2008 | 08:12 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
exhaust question
Well in the winter i plan on doing dumps on the car, i was just going to go from each header straight back and a muffler on each side with a turn down. The question is, is a X pipe or anything like that nessesary?
Old Jul 10, 2008 | 09:52 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: exhaust question
An X pipe is by no means necessary. Bear in mind that although exhaust flow may increase, your ground clearance sure won't.
Old Jul 10, 2008 | 10:22 PM
88bird?'s Avatar
Engine: built 350
No need for gorund clearance, thanks for your imput.
Old Jul 10, 2008 | 11:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which headers are you using? Do you mean you'll run the pipes literally straight back? If that's the case, you'll find out there's no room, you're going to need some bends in the way.
Old Jul 11, 2008 | 09:57 AM
88bird?'s Avatar
Engine: built 350
Im not sure what they are, i can get a picture of them if you want to see them, but yeah i noticed i will need to make some bends from the header to get it to the bottom of the car....
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
