Headers causing spark plug problems
Old Jul 19, 2008 | 09:50 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Does ANYBODY have a remedy to solve the spark plug problem you get with aftermarket headers? I have a 305TBI with Hooker shorty headers and now I can't get a socket on my spark plugs to either A) change them, or B) tighten them up. And you can't use a wrench on them because the hex sits underneith a lip on the block.
Is there a way to get something on the plugs or a special tool? Because the only way I know how to get to the plugs is by taking the headers off, which is NOT an option for me, especially on the passenger side of the block with all the A/C and A.I.R crap getting in the way over there.
Old Jul 20, 2008 | 12:58 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Headers causing spark plug problems
This is what I use with my shorty headers...
http://www.slponline.com/view_product.asp?P=30102
Hope this helps!
Old Jul 20, 2008 | 06:54 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I got a socket, looks like it as cut with a band saw, so shorter, and a ratcheing wrench, that you just put on end and turn, no flipping / re-adjusting, etc... I think I got it shippd for under $20... just looked and didn't see any...
Old Jul 20, 2008 | 08:15 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
i was able to use a regular old socket and ratchet with my hedmans.
Old Jul 20, 2008 | 10:56 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Hope this helps!
same here
Old Jul 20, 2008 | 11:27 AM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
i just use a deep well closed end wrench. it takes forever though. one end is 5/8 and the other is 3/4. which the 3/4 will fit on the end of the spark plug socket.
Old Jul 20, 2008 | 11:35 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
snap on spark plug socket
Old Jul 20, 2008 | 12:23 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I just took a spark plug socket and cut like 1/2 inch off of it and then I use 3/4 wrench on the end of the socket.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
