Hooker 2138 Headers...HELP!
Old Aug 9, 2008 | 10:24 AM
Neal Humby's Avatar
Car: 1986 Camaro Berlinetta
Engine: 305 carb
Transmission: 700R
Hi guys...just bought a new set of Hooker Headers #2138-1 ceramic coated
long tube headers...1 5/8" primaries/2.5" collectors
Now I need advice on collector extensions, straight pipes and mufflers!
I'm installing these on a 1986 Camaro Berlinetta, with 305 carb.
Any facts/ info would be appreciated,
Neal Humby
Old Aug 11, 2008 | 10:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Those route via the stock exhaust routing. Your best bet would be to have an exhaust shop (not a muffler shop) build the pipes to the stock cat location with 2-1/2" mandrel bent pipe, joining them with a good "Y" like the Flowmaster 2-1/2" into 3", and run a good 3" cat-back for the rest of the exhaust (Hooker Aerochamber, Magnaflow, Dynomax, etc.).
Old Aug 12, 2008 | 07:11 AM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
Re: Hooker 2138 Headers...HELP!
Thank you for your reply...I was really hoping to setup a true dual exhaust.
Because both headers point to passenger side, what collector extensions
would work for two separate pipes back to two mufflers?
Old Aug 12, 2008 | 09:13 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
a 305 dosent make enough power for true duals jsut do single 3"
Old Aug 12, 2008 | 10:27 AM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
so...2.5" to 3" y-pipe to hi-flow cat to flowmaster __________ (fill in blank,
please) ??
(Pooh, I wanted true dual)
Old Aug 12, 2008 | 02:05 PM
five7kid's Avatar
Were you planning on running true duals via the stock routing?
Really, though, you won't gain any performance, and you'll spend a buttload more money on true duals vs. a single 3" aftermarket cat-back.
Do you have your heart set on Flowmaster? If so, get one of the American Thunder cat-back systems. The '86-'90 TPI single cat application would be best.
Old Aug 12, 2008 | 04:11 PM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
I was going to do what "my cheap, deathly sounding exhaust" (in this webpages search) did...Will i gain any performance with the headers???
Old Aug 13, 2008 | 05:26 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
yea you should gain some nice HP with the LT's if im not mistakenif you really want true duals mabye you could do 2inch stright pipes lol or mabye 1.5" and really big tips
Old Aug 13, 2008 | 01:02 PM
five7kid's Avatar
Read this again:
Old Aug 13, 2008 | 03:26 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I was considering those headers at one time, let us know how the install goes (with pics if possible please).
Old Aug 13, 2008 | 04:08 PM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
Read this again:
Ok, I read that again! but can someone explain why the 305 gain is negligible? (my tach redlines at 5500)
I was hoping for better fuel economy at low revs and more horsepower at higher revs...
I seems I'm better off with that friggin y-pipe...just hate the way you see
it from pass side...perhaps a custom y-pipe and hi-flow cat wouldn't be
as noticeable....I'm still open to any suggestions!!!
Old Aug 13, 2008 | 04:37 PM
Mongoose's Avatar
Car: 90 Formula
Well, they seemed to help when GMPP used them during an LT1 install on the prototype 25th anniversary Z28 some years back. I know this is neither here nor there but I always thought ANY header would be better than a stock manifold.
Old Aug 13, 2008 | 05:22 PM
five7kid's Avatar
I was speaking to 91z 2 8 with regard to his comments about straight pipe and the like.
The gains are negligible because other restrictions remain, such as the factory low-lift cam, single snorkel air cleaner, 2-1/4" cat & cat-back. The headers will help upgrades to those parts work even better, but if you don't do anything about them, the improvement from the headers alone will be negligible. The 1-1/2" primaries of the 2138HKR's work well with a 305 and will maintain higher exhaust speed, which improves low-RPM response and fuel economy.
I seems I'm better off with that friggin y-pipe...just hate the way you see it from pass side...perhaps a custom y-pipe and hi-flow cat wouldn't be as noticeable....I'm still open to any suggestions!!!
You want to see things dangling down in an ugly way, go true duals.
Old Aug 14, 2008 | 08:28 AM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
I appreciate the thoughts Five7kid. I have already got rid of the stock intake.
Now have edelbrock top breather on carb and will go 2.5 to 3 inch from Y pipe
back...will that help a little?
Old Aug 14, 2008 | 05:46 PM
five7kid's Avatar
The top breather doesn't help much because it sits right in the hood blanket, and it's just letting in hot underhood air. A dual snorkel air cleaner that scoops cool air from the front of the hood is a much better set-up.
The stock intake isn't restrictive until you do other upgrades such as cam.
3" from where the two banks join on back along with the headers will help. Just don't keep the 2-1/4" stock cat in there.
A cam upgrade, along with headers & exhaust, dual snorkel air cleaner, and intake upgrade will really wake the car up.
Old Aug 15, 2008 | 06:41 AM
Neal Humby's Avatar
Engine: 305 carb
Transmission: 700R
You are a wealth of knowledge five7kid! OK, I'm going out on a limb here...what cam would you recommend? Does a cam change mean other parts too?
I probably won't do it right away, but I could setup the exhaust now, right?
Old Aug 15, 2008 | 11:58 PM
five7kid's Avatar
The more modern grinds like Comp XE, Crane Compucam, etc., work pretty well with other mild upgrades. A Comp XE262 would work with headers & air cleaner upgrade. Any bigger than that, and you'll need a higher stall torque converter (although even the XE262 would probably respond well to more stall).
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
