Adding to Dyno Dons Headers and Y Pipe
Old Aug 23, 2008 | 09:53 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Looking up upgrade after Dyno Don's y pipe. Would it make much sense to increase from my 3 inch catback to a 3.5 or even a 4 inch. Will the 2.5 inch y pipe even flow enough to fully use a 3.5 or 4 inch mufflex or should I keep my 3 inch on right now?
Old Aug 23, 2008 | 10:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Adding to Dyno Dons Headers and Y Pipe
Some things to ponder. Two 2.5" pipes equal 9.8 square inches. One 3.5" pipe equals 9.6 square inches. Pretty close. One 3" pipe equals 7 square inches.
Old Aug 23, 2008 | 10:12 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
So you really would not gain much going to a 4 over a 3.5 with a 2.5 inch y
Old Aug 23, 2008 | 11:34 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The other point to ponder....
You might need 9.8 sq. ins. at the collector,(when ex. is hot) but by the time the exhaust condenses down the line, you probably won't need more than 7.5 sq. ins.(because it cools and therefor reduces in volume).
In other words, there are plenty of 11 sec. & low 12 sec. cars using 3"
Old Aug 24, 2008 | 09:48 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
And having a 3 inch cutout right after the y pipe probably helps a bit also
1984HO
Mar 19, 2021 11:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
