angle plug heads
Old Sep 4, 2008 | 12:58 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
angle plug heads
i have access to a set of RHS angle plug heads and the only thing thats holding me back is header clearance. i did a search and found a pic of a fellas (monsooni) camaro and the plugs didnt look that bad to access.
what is the general census experience with angle plugs and headers?
Old Sep 4, 2008 | 09:18 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Re: angle plug heads
I run long tube Hookers with angle plugs. I use a standard length plug with heat boots. Not a bad install using the Hookers. 2 plugs i have to use a wrench on but other than that not bad.
Old Sep 4, 2008 | 10:33 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
which are the hardest plugs you have to deal with, the front of the motor or back of the motor? if its the front im not sweatin it. i have a socket set from work (powerhouse tools) that gets into the tight spots on my current stright plug heads with headers and its a snap. it takes more effort to get the boot off than it does the plug.
Old Sep 5, 2008 | 10:47 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Plug #1 is the worst with the Hooker.
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
