Hooker 2210's, T-56 and Mufflex 4" done!
Old Sep 12, 2008 | 06:54 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Just thought I post up pics of my Hooker 2210 longtube headers and Mufflex 4" cat back exhaust in my T-56 converted (Skulte Longtube Xmember) Z28. I had a local exhaust shop fab me up a Y-pipe. I gave him a Flowmaster Y scavenger (dual 3" into a single 4") and told him to keep the ground clearance as best he could. You can really tell from the pics, but the header collectors are the lowest point in the whole system!
Attached Thumbnails Hooker 2210's, T-56 and Mufflex 4" done!-dsc00446.jpg   Hooker 2210's, T-56 and Mufflex 4" done!-dsc00447.jpg   Hooker 2210's, T-56 and Mufflex 4" done!-dsc00448.jpg
Old Sep 12, 2008 | 06:55 PM
Randy92Z's Avatar
Engine: Miniram 383
Re: Hooker 2210's, T-56 and Mufflex 4" done!
More pics.
Attached Thumbnails Hooker 2210's, T-56 and Mufflex 4" done!-dsc00449.jpg   Hooker 2210's, T-56 and Mufflex 4" done!-dsc00450.jpg   Hooker 2210's, T-56 and Mufflex 4" done!-dsc00452.jpg
Old Sep 12, 2008 | 09:17 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Fantastic job. You should be proud of yourself.
Old Sep 13, 2008 | 10:44 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Do you think there was anyway for him to raise it up in the middle area? Main reason I'am asking is cause I have the mufflex 4" and flowmaster scavenger with the Skulte Longtube Xmember comming. I'am looking for Idea's before I tear everything apart this oct.
Old Sep 13, 2008 | 06:50 PM
Randy92Z's Avatar
Engine: Miniram 383
Nope! Its pushes the xmsn up a tiny bit more than my Spohn one did, and I can see a wee bit of chaffing from the xmsn mount on the Skulte xmember already. I going to do a little clearancing on the metal part of the xmsn mount to fix the chaffing. It looks to me like everything is as far "up" as it will go. Hope that helps.
Old Feb 19, 2009 | 08:57 PM
Pingu 2.0's Avatar
Car: 1987 IROCZ
Engine: 5.0L TPI
Axle/Gears: BW 3.45
how was the fit of the mufflex catback? i've heard the 3.5" is hard enough.
Old Feb 19, 2009 | 09:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Looks good. you have alot more clearance than my setup with the spohn xmember and auto trans. I went under the frame rails and paid for it with crushed y pipe. that was 3" piping, and it did touch bottom of the road alot. yours looks much better. T56 and T56 xmembers help alot with 2210's
Old Feb 19, 2009 | 11:26 PM
Randy92Z's Avatar
Engine: Miniram 383
Better than I thought it would. I thought it would rattle against the frame from time to time, but so far its been great. ALOT louder than my SLP shorties and Flowmaster 3" cat back!
Old Feb 20, 2009 | 06:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you can fit 4" single exhaust on these cars without too much problems.
Old Apr 28, 2009 | 03:53 PM
kerplunk318's Avatar
kind of old post, but how much did that y pipe cost you? was it a 3 inch?
Old Apr 28, 2009 | 06:53 PM
Randy92Z's Avatar
Engine: Miniram 383
Yea, its a 3" pipe. I think it was around $200 for it.
Old Oct 23, 2009 | 02:16 PM
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
I know this is old, but I just had to subscribe.
How do you like your Muflex kit? Which one do you have?
Old Oct 23, 2009 | 05:50 PM
Randy92Z's Avatar
Engine: Miniram 383
I love it! I have the Spintech muffler single 4" out kit. Although Im in the process of swaping out the Spintech muffler with a Dynomax ultra flow Muffler.
Old Oct 23, 2009 | 06:29 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It wont sound as good, but you might pick up a couple of ponies by switching mufflers.
Let me know what kind of a difference it makes, I'm curious!
Old Oct 23, 2009 | 07:56 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
thats a great looking system
Old Oct 24, 2009 | 10:41 AM
David 91RS/Z28's Avatar
I was going to advise in swapping out the Spintech. They sound killer but are horrible for actual exhaust flow. We basically have identical setups cept mine is in the 3.5" and I swapped the Spintech to a Hooker Aerochamber. Was worth another 10 to the rear wheels. But I've seen much more gains from ditching the Spinners on cars!! Nice car BTW!!
Old Oct 24, 2009 | 03:34 PM
Randy92Z's Avatar
Engine: Miniram 383
Exactly! Ive been reading some posts about people picking up 20-30 rwhp swaping out the Spintech muffler. Some say that they have to re-tune the car and add a bunch of fuel to get there A/F ratio correct. Ive been expecting to pick up 20 rwhp, from the muffler swap myself.
After replacing my old exhaust, (Flowmaster 3" cat back, SLP headers) I went back to the dyno with my new Hooker 2210's, and 4" Mufflex exhaust I picked up 38 rwhp without any tuning yet! So it will be interesting to see what will happen on the dyno once I get the Ultraflo on and tune it.
Old Oct 24, 2009 | 05:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
....let alone the weight loss by going to another muffler. Those Spintechs are heavy.
Old Nov 17, 2009 | 12:33 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Hi Randy92Z
nice looking Exhaust..
dont know if you are looking at your photos..but you need to get that rust off your SFC's. and get a somthing on them.. before you have to replace them.. the tube style is not up to alot of rust. when it comes to stoping the flex.. just so ya know..
on aside note: i wish my car came without all the Black stuff the dealer sprayed under My 92 when i picked it up.. i pasted on the cost as it was going to be a drag car..then the nexed day when i came to pick it up... they told me
"hey we just added that for free has a thank you"
why do you think i told you i did not want it..
there was like 10 lbs of that stuff on there..
Old Mar 30, 2010 | 06:11 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
its all about the sound! spiners sound killer. I only wish they made a 4 inch aerochamber
Old Mar 30, 2010 | 08:06 PM
Randy92Z's Avatar
Engine: Miniram 383
It does sound good, Im not gonna lie, LOL.
Old Mar 30, 2010 | 08:33 PM
Car: 02wrx/88 rs
i would say its worth the power drain. Lol
and the weight in the rear helps get closer to 5050 weight distribution lol
hooker if you are listening make us a muffler!
Now the only thing holding me back is a crosmember that im satisfied with lol
Old Apr 8, 2010 | 12:45 PM
Car: 02wrx/88 rs
so you had a spohn crossmember but then got that one?
Old Apr 8, 2010 | 12:58 PM
Randy92Z's Avatar
Engine: Miniram 383
Yes, when I had my SLP 1 3/4 shorties on there with a Flowmaster 3" cat back system, I ran the Spohn xmember. Then I got the Hooker longtubes, Mufflex 4" catback and Skulte xmember at the same time and installed it.
Old Jun 17, 2010 | 10:02 PM
JustinWest88's Avatar
Car: 86 Camaro
Engine: 73 350, about 425 hp, carbureted
Axle/Gears: 7.5/ 3.42:1/ welded gears:/
hey yall i'm looking into the mufflex system too, having a little trouble picking out a muffler and cat for the system. i've been out of the car scene for a few years so lost contact with most local enthusiasts. i'd like to have a the dual outlet spintech muffler but have no idea what it would sound like. seems that yall like it? i'd like to put a cat in the system as well to keep it legal and worry free, any input of those who have worked with this system? thanks guys!
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
