Odd Exhaust Question
Old Sep 13, 2008 | 10:04 PM
barristerjim's Avatar
Car: 87 IROC-Z
Engine: 305 TPI (LB9)
Right Different than Left?
On Thursday I had a new Magnaflow muffler, high flow cat, 3 inch piping, and Magnaflow tips installed at a locally owned exhaust shop with a good reputation. I just noticed today while in park and at warm idle the passenger side exhaust will have kind of have a popping tone to it that is not heard in the driver's side portion of the exhuast. It isn't real noticeable but there is definately a difference between the two exahust tips if you listen for it. There doesn't seem to be any difference when you first start the car or rev the engine and I only notice the different pitch when the engine is idling after warming up. I didn't notice any difference before with the old Xlerator muffler that was previously on the car, but naturally I'm paying more attention now after just having the new exhaust system installed. Should both sides sound exactly the same or will there be one dominant side in a single cat back system resulting in some sound variation? Otherwise the car seems to run and sound great. As always thanks for your input.
Old Sep 15, 2008 | 11:42 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: Right Different than Left?
If you look underneath the car you should get your answer. With a single exhaust setup, the pipe goes into the muffler and then branches out to the driver & passenger side. So, you have one tailpipe that is closer to the exhaust input to the muffler, and that will cause a dominant side.
Old Sep 15, 2008 | 07:13 PM
Car: 87 IROC-Z
Re: Odd Exhaust Question
That's what I suspected. Thanks for the confirmation.
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
