Headman Install
Old Sep 29, 2008 | 07:55 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Headman Install
I just finished installing my headman headers on my engine- which is on the engine stand still. I have the Headman Y-pipe that came with the Hedman headers from summit.
My question is that when I mocked the ypipe up to the headers the driver side collector adapter on the y pipe doesn't appear to long enough.
I can get it close to picking up the header but the y-pipe then hits the oil pan. Seems as though it will be an easy exhaust shop fix to correct it.
fab. a longer collector adpater to slip into the ypipe? anyone else have this problem?
There are headman headers with AIR on a 350 with HO heads
Old Sep 29, 2008 | 08:12 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: Headman Install
The drivers side is adjustable to the length you need... They are shorties right?
Old Sep 30, 2008 | 08:27 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Re: Headman Install
Yea they are shorties...
To better clarify.. the driver's side collector dumps just next to the oilpan's hump... the length of the stub collector that you slide into the Ypipe to mate up to it seems right but the angle and length of the vertical section (rises to mate to the header is too short/wrong angle.
Now I am running a Moroso 6 qt oil pan without kickouts... (learned that the hard way.. hard to ship back my 9 qt. oil pan with kickouts for interference problems)
I figure worst comes to worst I can install the engine run with headers to the exhaust shop and have them fab up a new collector?
Old Sep 30, 2008 | 11:29 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: Headman Install
the Y-pipe was designed to fit around a stock oil pan... so I believe your going to have to have someone fab it up.. I would try to use a local shop... (they tend to bend the rules a little...)
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
