Few Exhaust Questions
Old Oct 1, 2008 | 08:07 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
Axle/Gears: 2.73 open
After searching I am left with a few unanswered questions.
1) Are there any LT headers that will bolt in? Not require a mini-starter, bashing of frame, etc?
2) Will one of Summit's universal X-pipe kits fit? I know some vehicle's crossmembers don't allow for x-pipe use.
Old Oct 1, 2008 | 08:13 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: Few Exhaust Questions
I don't believe any LT headers will just be a bolt in. As for the x-pipe..it'll work if you can weld. You can't do anything besides stock placement single exhaust without modification. And sometimes that still requires some kind of modification.
Old Oct 2, 2008 | 07:00 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
basically u have to run inthe stock locations... still tho ive done this before and sum things arent as easy as 1,2,3. as far as LT headers that fit... there are a couple... headman, hooker, doug headers, etc... anything used even if its not stock requires custom everything. even aftermarket shortie headers that run in the stock location require there own aftermarket Ypipe or custom Ypipe.
there is no xpipe/hpipe designed for our car... that is also a custom mod u would have to do... still tho if u can i would do it. i have headman LT's, 3" headman S bend header extensions, 3" summit universal xpipe, and 3" force mufflers with turndowns. mine is compleley custom... done by me. worth it yes, but u have to be cleaver and have the tools and time needed to do the work.
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
