why are some headers not good for engine swaps?
Old Oct 31, 2008 | 09:50 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
ok im on a budget 350 build so its gonna have a budget exhaust (budget not cheap mmm-kay?) and i was considering these but under application the 8th line down says "engine swap: no" so my question is why? whats the difference between a set that says "engine swap: yes" and "engine swap: no"? man theres to much to think about considering its a bunch of pipes
Old Oct 31, 2008 | 09:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: why are some headers not good for engine swaps?
It means they're for an original-type engine (in this case an SBC), and not a BBC or a Pontiac or something.
Old Oct 31, 2008 | 10:08 PM
Brennan's Avatar
ok so since im using another SBC those headers will work for me right?
Old Oct 31, 2008 | 10:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but by the time you've added a Y pipe to those you could end up paying more than you would have for the 2055s.
Old Oct 31, 2008 | 10:37 PM
Brennan's Avatar
not gonna have a y pipe per say my plan is to run two 2 1/2"-ish pipes side by side in the stock location and use a muffler with a built in x-pipe
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
