Header wrap....
Old Nov 8, 2008 | 11:54 AM
fearthisinc's Avatar
Header wrap....
ok so I had my headers installed and the guy decides to tell me after the install that i should get the headers wrapped.. which is obviously harder being that they are already in.. just wondering if anyone has any advice on wrapping these being that they are already installed... thanks
Old Nov 8, 2008 | 12:06 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Header wrap....
I wouldn't bother.
JamesC
Old Nov 8, 2008 | 12:09 PM
Re: Header wrap....
well they said that there are alot of wires near the headers and the heat will melt them.. i think he said the ignition wire or something like that is right near them
Old Nov 8, 2008 | 12:17 PM
JamesC's Avatar
Re: Header wrap....
I run unwrapped, uncoated Hooker 2055's with no problems. I have made an attempt to keep the wiring, to include plug wires, safely tucked away. If your wiring looks like spilled spaghetti under the hood, then who knows what the results might be.
Check my Car Details below for a pic or two of the engine bay.
JamesC
Old Nov 8, 2008 | 03:04 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Header wrap....
I will say this....NEVER ever wrap headers, all makers will void your warranty if you do.
It holds in the heat and destroys the metal.
Old Nov 8, 2008 | 04:11 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: Header wrap....
Not only will the excess heat destroy them, but when they get wet, it will also hold moisture (like when the car sits without being driven for a while)
I'd recommend getting them coated by Jet Hot, or for the time being you should consider getting some DEI spark plug heat boots. I ran uncoated SLP headers for about 2 years. While the heat boots protected the wires from melting, I did have multiple starters die from heat soak, had wire loom melt in some spots, and at one point I had a few dried leaves around my windshield wiper arms (car was a daily driver then) and popped the hood with the motor warm--One leaf fell directly down to the middle of the header collectors and started smoldering and then became an actual flame. Only thing I could do was blow it out. I got lucky and nothing got burnt. I don't want to think about what would have happened, had it not gone out as quick as it did.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
