Changing muffler on stock exhaust?
Car: 82 T/A 47,XXX
Engine: 305 until the ZZ4 355.
Transmission: turbo200
Axle/Gears: 3.42's
I have a 82 TA with a 305, it has manifolds - Y pipe - Into a cat - that runs into a stock muffler dual outlet with tips.
I was wondering If I maybe changed the muffler to say a flowmaster with diffrent tips will it be a little louder ? right now its to quiet. I was thinking maybe even doing a cat delete?
What size does the muffler need to be such as inlet outlet, and where can I get some nice tips?
Thanks guys
- Josh
Thanks guys
- Josh
Transmission: 4L80E/4L80E
Which 305, the carb'd LG4, or Cross Fire?
Stock your car should have had dual mufflers. If it is a single muffler now, no telling what has been done.
Best bet is for you to crawl under and measure yourself. Or, just get a cat back system.
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L 350
Re: Changing muffler on stock exhaust?
My car has one muffler stock. I have a flowmaster on it, and some tips, and it's pretty loud. Louder than most cars.
..............bout to put some slp headers on
Michael, your car is a '91, right? I'm talking about '82-'83 models.
Engine: 5.7L 350
Ok, I was not sure if he had the same exhaust set up or not. Also mine has a 350, so the sound may be different. But the flowmaster is pretty good. Did those 82-83's have dual exhaust?
Car: 82 T/A 47,XXX
Axle/Gears: 3.42's
it has just like I said, factory cross fire car, someone ruined the old drivetrain it has a 84 motor and tranny out of ????
You're going to have to get under there and look/measure. No telling what's been put in there, or if it's stock.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I think your going to have trouble removing the stock mufflers. Might want to take it to a shop unless you have tools of your own. I needed to take out the old grinder and go to work.
Car: 82 T/A 47,XXX
Axle/Gears: 3.42's
Ok so maybe I lied LOL. I looked under there and its 2 smaller mufflers. now what do I do about this??
Car: 82 T/A 47,XXX
Axle/Gears: 3.42's
I don't think so. The inlet of a single muffler will be in a different place than that dual muffler set-up.
1992 Trans Am
May 10, 2023 07:19 PM
