02 senser and shorty headers
Old Nov 13, 2008 | 12:34 AM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
I have a 92 camaro and I am installing a set of shorty headers do I need a heated 02 senser or will the stock one work
Thanks Shawn
Old Nov 13, 2008 | 12:49 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 02 senser and shorty headers
You dont have to run a heated O2 sensor, but the engine will perform better at idle with one. Its only at idle that there is an issue. Once you start moving and the exhaust starts flowing, the O2 sensor gets enough heat.
The O2 sensor needs heat to work properly, and installing headers moves it further away from the hot exhaust right out of the cylinder heads.
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Night rider327
Sep 16, 2015 02:20 AM
