EGT install
Engine: 350 TBI
Transmission: manual
Axle/Gears: 4.11
EGT install
Searched but didn't see much info on EGT installations. Do y'all drill and tap the exhaust manifolds before the Y pipe flange? Or weld a bung downstream in the Y pipe somewhere?
This is on an L05 motor with center dump, cast iron rams horn manifolds. The EGT probe uses 1/8 NPT fitting.
Thanks a lot.
Thanks a lot.
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
Re: EGT install
Thanks a lot.
Thanks a lot.
gixxer92
Sep 1, 2015 04:32 PM
