cat?
Old Dec 6, 2008 | 09:54 PM
89T-top's Avatar
Car: 89 camaro rs
Engine: 3970014/block 350
Transmission: 700r4/shift kit
Axle/Gears: 2:73/going with 3:73's soon
cat?
Hay all, I have to take my car in for inspection here in Ohio since I bout it in Michigan. my question is do I have to have a catalatic converter?
It's an 89 camaro rs so it would have come with one from the factory.
It's not vary loud since the exhaust is stock besides having no cat. I would hate to loose the only v8 rumble I got.lol
Thanks -Tony
Old Dec 6, 2008 | 10:26 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: cat?
If you have a visual test you will fail but if its just the sniffer then you might pass
Old Dec 8, 2008 | 12:23 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: cat?
Its very tough to pass the sniffer without a cat.
Plus its required by federal law that you have one, since the car came with one.
Old Dec 8, 2008 | 04:10 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: cat?
agreed, you're not going to pass any emissions test with a used thirdGen without a cat. It will never pass the sniffer.
TA
Old Dec 8, 2008 | 05:39 PM
89T-top's Avatar
Car: 89 camaro rs
Re: cat?
yeah they where telling me at the DMV to take it to the Chevy dealership to have the inspection done, So I got a felling they will put it up on a lift and take a look at my undercarriage.lol
Oh well I seen I can get a nice high flow cat on summit for about $60 dollars shipped. I think I'll just play it safe and order one that way I don't ever have to worry about it.
Thanks for the info guys.
Old Dec 8, 2008 | 07:47 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: cat?
@ TA: Not true, buddy of mine had a stock cat and exhaust, the dirtiest air cleaner ever, no oil change in 25000 miles, when we removed his intake manifold the passages were caked and blocked with sludge (after emissions test)...
He passed easily....this was also without smog hooked up.
HOWEVER, my brothers freshly rebuilt to stock, headers, full exhaust with cat, new fluids, new intake, o2 sensor and tune...(leaned specifically to pass), didnt pass.
We ended up adding 98% alcohol to his gas and that gave him the (30-40 points) needed to pass.
and
My completely fin Z31 V6 fully stock, new cat, o2, intake full tune-up the works...didn't pass.
My 89 camaro, no smog (tubes removed, cat plugged), clean car....passed.
So to me, I think its a hit or miss sometimes...that and I have had it where 2 different places gave me readings a good 100 points different from each other...in the same day...so yeah.
Get a cat...then afterwards (after you pass), replace with test pipe, easily changed, back to loud.
Old Dec 9, 2008 | 09:02 PM
89T-top's Avatar
Car: 89 camaro rs
Re: cat?
and
It's got a 79 350 so I have no smog pump or lines I'll have to plug the line on the cat, I hope they don't make a big deal out of that.
I'm going to order my cat Friday. I was thinking of going with a magnaflow cat off summit, y'all think that would be OK or should I just get a stock replacement, I would like the exhaust to flow a little better than stock.
Old Dec 10, 2008 | 10:09 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: cat?
If you plan to rid of the cat after you pass, just get a stock replacement or one of the same size and the cheapest you can.
But if you plan to keep a cat, Magnaflow is what I am going with...polished too...haha
This is the cat I will be buying....you dont need to get polished but my whole exhaust will be
NOTE: This version (Part Number 94309) is the one without air tube, picture shown is with same one but with air tube.
http://store.summitracing.com/partde...part=MPE-94309
There are even cheaper versions....and this one is 49 state legal...good for me.
Old Dec 10, 2008 | 12:51 PM
89T-top's Avatar
Car: 89 camaro rs
Re: cat?
here is the one I was thinking of going with.... Mainly because it is the cheapest and should flow better than a stock cat would. I'm going to keep it on Just so I know the car will be legal.
I have headers and a flow master muffler with stock size piping so my exhaust should flow a little better than stock.
here's a funny thing a stock cat would cost me $89 and the Dynomax is only $57.
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 10, 2008 | 01:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: cat?
that is the better cat wwd. it is 3" in and out and will not create back pressure if you have a 3" collector and 3" pipes.
Old Dec 11, 2008 | 09:04 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: cat?
Most aftermarket parts are....
Old Dec 12, 2008 | 01:50 AM
89T-top's Avatar
Car: 89 camaro rs
Re: cat?
Ended up going with the polished magnaflow, Not bad for $67 bucks shipped if ya gotta have it. I just hope it's not to cold up here in Ohio when I'm putting the dame thing on.lol
http://www.amazon.com/MagnaFlow-9400...9062259&sr=8-5
Old Dec 12, 2008 | 08:24 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: cat?
Lets hope amazon doesnt mix it up with the California type converter Part # 94006CA....as some places dont designate the CA...
If so what could be different from a CA converter than a 49state converter? Do the CA cats burn more toxins up or something?
Old Dec 12, 2008 | 01:01 PM
Kevin91Z's Avatar
Re: cat?
No, the only difference is CA makes the manufacturers submit their products to an additional test that costs more money. The cats are fine as they are made but CA's air quality management district doesnt have anything better to do.
Old Dec 17, 2008 | 07:21 AM
jacque_strap's Avatar
Re: cat?
... HOWEVER, my brothers freshly rebuilt to stock, headers, full exhaust with cat, new fluids, new intake, o2 sensor and tune...(leaned specifically to pass), didnt pass...
That might be your problem - CATs work best at stoich. Leaning out your AFR just makes things worse.
Old Dec 17, 2008 | 08:14 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: cat?
Can someone else verify this? If so then, haha to me. But you learn something new everyday...especially with cars.
Old Dec 18, 2008 | 12:30 PM
Kevin91Z's Avatar
Re: cat?
Leaning out the fuel mixture does make the exhaust burn hotter (glowing headers, anyone?). The higher temps could make the cat fail.
Old Dec 18, 2008 | 08:38 PM
89T-top's Avatar
Car: 89 camaro rs
Re: cat?
Well got it mounted tonight just waiting for my dad to get over here and weld it up for me.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
