where and how much to cut on a-arm bracket?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
well like the title says, i installed hedman longtubes today and the hit on the a-arm mounting bracket. my question is, how much can i trim off before it is a problem?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: where and how much to cut on a-arm bracket?
you can trim as much as you need to get the headers to fit, i did, and there is no problem, its not really a structural part of the a-arm anyways
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I hardly cut mine at all when I installed my long tubes. I remember grinding a good bit on the bracket but never cut it.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I got tired of pulling my headers in and out to keep removing more material, so cut off the corner and welded a plate in diagonally. As long as there is enough room for the bottom of the A arm to pivot, and you enclose it again so it isn't weakened too much, taking some off makes on difference. Really, I have no idea why GM made them so large to begin with, probably for ease of construction.
TA
TA
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i never had to cut on my 82 or my 86 to get mine to fit.
well i got them on, didnt cut too much, i did grind some off. more clearance now then there was now. wow, just longtube headers is loud!!! before i had shorties and a y-pipe and this is sooo much louder then that.
Hello, Michael
Sep 11, 2015 01:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
