TES Edelbrock Headers
Old Dec 7, 2008 | 04:30 PM
SERIO's Avatar
Car: 1991 CAMARO RS
Engine: 5.0L 305 TBI
Hello ppl,
Well idk if this is the right place to start this thread but i put on some TES edelbrocks on my RS. During the installation we broke the sensor below the stock manifolds on the passenger side which r now the TES edelbrocks. That sensor is the fan switch sensor which we replaced as soon as it broke. So we replaced it then we bolted on the headers and at the end we plugged the wire into the sensor but i guess the sensor had like a plastic clip or something and it was broken. So the wire going into the sensor isnt very well clipped on, well its in all the way but not clipped. So the reason why i am saying all this is that now when i drive the RS when i guess the engine get to its regular temp. instead of staying in the 220 mark or lower in the temp. gauge it goes past it to the next line. I would like to know if this is normal and if this happens to everyone with TES edelbrocks. Hope hearing some feedback.
Edgar
Old Dec 7, 2008 | 06:09 PM
SERIO's Avatar
Car: 1991 CAMARO RS
Re: TES Edelbrock Headers
Plz guys.
Need some info
just want to make sure if its normal or not
Old Dec 7, 2008 | 06:14 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i have the edelbrock on mine and no its not normal you should recheck your connection at the sensor sounds like it s a bad connection still go to a junk yard or somewhere and get that plastic connector so it fits snuggly again
Old Dec 7, 2008 | 06:21 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
you could purchase the "pig tail" for that sensor you should be fine after that, any major auto parts will carry them and if not they will be able to order that connection "pig tail"
Old Dec 7, 2008 | 06:30 PM
JMR's Avatar
JMR
the knock sensor pig tail will also work for the cooling fan switch.
Old Dec 7, 2008 | 10:21 PM
SERIO's Avatar
Car: 1991 CAMARO RS
Oh ok then cool
Thanx guys
I appreciate ur feedback
Old Dec 8, 2008 | 12:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You'll need to cut off the old broken connector and solder on the new pigtail connector.
Old Dec 8, 2008 | 02:09 PM
SERIO's Avatar
Car: 1991 CAMARO RS
Ok cool
i will do that
Hotrodboba400
Dec 10, 2019 07:07 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
