Which Headers Should I Stick With?
Old Dec 9, 2008 | 10:25 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
The headers right now on my car are the funky Edelbrock (I believe they're longtubes) ones that prevent proper routing of the spark plug wires on the passengers side.
They get the job done for now, but overall not too impressed.
When I picked up that 350 that turned out to be a boat anchor, I got a set of hooker headers with it. I cant remember the model on them. They go for about $140 at summit. I believe they are shorties.
When the car hits 25 years old, I am considering removing the AIR system. The Edel headers in there right now have the air injection tubes, and the Hooker headers do not. But aren't the air tubes required to pass visual state inspection?
The hooker headers aren't in too bad shape. They have some rust, but a quick sand blast and some paint and they should be good as new.
Thoughts?
Old Dec 10, 2008 | 12:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Which Headers Should I Stick With?
If your area has a visual inspection, yes they are supposed to check to make sure you still have the air pump and air tubes.
Edelbrock's are shorties, they dont make long tubes to my knowledge.
You could also get a set of Dyno Don's headers. Search this Exhaust forum for "dyno don headers" and then send him a PM.
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
