L03 exhaust manifolds
Old Dec 15, 2008 | 04:05 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
Is there a difference between L03 exhaust manifolds that come on '88-'92 F-bodies and L03 manifolds that come on '89-'92 Caprices besides different y-pipes, i.e. could you use a manifold from a Caprice on an F-body? And are the L05 manifolds from Caprice/Fleetwood/Roadmaster the same as TPI or L03 manifolds?
Old Dec 15, 2008 | 02:03 PM
82taluver's Avatar
Car: 1991 GTA
Transmission: M5
Re: L03 exhaust manifolds
should be the same basic thing. same mounting at least, although the angle of the outlet may be different depending on the application. like on my truck the manifold outlet is near straight down, whereas on the f-body i believe it is angled back more. experiment and good luck
Old Dec 16, 2008 | 01:24 PM
What about LU5 crossfire manifolds? Is there any difference between the LU5 and the LO3 manifolds? I'm asking because I'm restoring my Iroc to as close to original as possible, it will be a cruiser mostly. I currently have Edelbrock TES headers and a Flowmaster(American Thunder) cat-back on the car now. I want to put factory manifolds and y-pipe back on it and a quieter 50 series 3 chamber muffler. TPI y and intermediate pipes are a little costly new' that's why I'm asking about LO3 and LU5 exhaust manifolds, both of which I may have easy access to.
Old Dec 16, 2008 | 11:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As far as I know, the only manifolds and y-pipe that will work with thirdgen f-bodies is other thirdgen f-body parts. The angles and direction of the pipes are specific to our cars.
And the L03/LG4 stuff is smaller and made for low-power. Keep trying to find the good TPI stuff.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
