what headers and full exhaust fit best?
Old Jan 6, 2009 | 04:58 PM
73duster's Avatar
i will be dropping a 383 stroker with first tpi in the 91 z28. I want to know which headers do you guys find to fit the best with the least hassle. Also the rest of the exhaust, should i go full dual or would a y pipe fit better? I want performance, but not at the cost of poor fit. I don't mind losing a couple of horses if the fit and sound are good. Also, do any headers come with o2 bungs already or do i have to get them welded in? What do you tpi guys run?
Old Jan 6, 2009 | 05:10 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: what headers and full exhaust fit best?
i was gonna say but you dont even need to cuz its a sticky
Old Jan 7, 2009 | 12:12 PM
73duster's Avatar
I checked the stickies but i'm not clear on which headers fit best. I'm new to chevy and my only experience has been mopar. The only thing i see is that hooker long tubes make changing plugs difficult. I'm not concerned with performance, only fit. I figure any headers will improve hp. Again, sorry if this has been answered before.
Old Jan 7, 2009 | 12:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For a 383 you're gonna want a set of Dyno Don's 1 3/4" shorties and y-pipe. You can search the Exhaust forum for "dyno don headers" and send him a PM for the details.
A single 3" or 3.5" exhaust will fit a lot better than true duals will.
Old Jan 7, 2009 | 08:07 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Your plug clearance will depend on the style of heads/ plug locations that you use. Almost all of the headers for our cars were designed for the stock plug locations, so with stock plug-location head are tough and upgraded heads become impossible. I agree with Kevin91Z, for the best fitting/best plug access headers for any heads and by far the best performing "shorties", go with Dyno Dons. All the long tubes have major fitment/frame clearance/ground clearance issues, and require a custom exhaust to connect it to. Don't go there unless you are a glutton for punishment.
TA
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mustangman65_79
Aug 7, 2015 09:55 PM
