Accesories with Headers
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
For anyone that has headers installed, how do you accommodate the accessories that mounted to the OE manifold studs? I have a 91 Z28 with AC and AIR pump. The AC may have a bracket, but I know for sure the altenator has a braket on it's backside that mounted to the front driverside manifold stud, and the Engine oil dipstick also mounted to a manifold stud on the passenger side. For my headers, I had to use smaller head bolts. Are there kits to remount this stuff, or was fabrication required?
Thanks,
Thanks,
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Accesories with Headers
I used the stock longer studs in those holes and bolted the brackets back onto them.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My bad, I guess I forgot to include the two spacers.
Get some tubing from the hardware store, 3/8" inside diam. 1 1/4" long and reuse the stock bolts on #1 bolt left side and #3 bolt right side.
Sorry 'bout that.
Sorry 'bout that.
redformula88
Oct 14, 2015 06:08 PM
