need catalytic converter help
Car: 89' RS camaro Convertible
Engine: 305 TBI
I need help on what the lil tube on the cat is for and what does it do and do i really need it on to pass smog.
Here are some pics for what im talking about
Engine: 305 TBI
Re: need catalytic converter help
what would happen if i disconnect it like if i take the cat off and run a straight pipe..im not talking about for smog any more
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
When you remove the cat, you'll need to do something about the pipe that connects to that tube. You'll have to find a way to plug it or remove it al together.
my understanding is that the smog pump simply pumps excess air into the exhaust to let the catalytic converter work more efficiently. so by removing the catalytic converter, there is really no point in having the smog pump anymore...
Engine: 305 TBI
talking about the tube
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You live in California. Get any and all thoughts of removing the cat or gutting your cat out of your head. Its completely illegal to drive it on the street that way.
If I can run 12's in the 1/4 mile, make 350+ horsepower to the wheels, get 20+ MPG on the highway, daily drive my car, and pass CA's tough smog test, so can you.
We hot rodders already have a bad name, no need to make it worse.
But if you're making this into a race car, not a street car, then no, removing the cat, or the air pipes, will not affect the computer at all. Only the EGR is monitored by the computer. Oh wait, your EGR system on your TBI engine is affected by the exhaust, so without the cat there, or with a bigger exhaust, several TBI members have reported getting EGR code 32's after removing the cat.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
