Delete cat to make exhaust louder?
Old Feb 25, 2009 | 06:46 PM
  #51
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Delete cat to make exhaust louder?
Originally Posted by chesterfield
Well, the moderators at TGO need to get busy. Doing any of the following is as illegal as removing a cat.
* Removing the EGR valve or plugging its vacuum lines
* Removing or disconnecting the PCV valve
* Removing the stock air cleaner and heat riser duct plumbing
* Removing the catalytic converter
* Removing or disconnecting the air pump
* Removing or modifying the stock distributor vacuum advance/retard
* Altering the stock ignition advance mechanism or timing curve
* Replacing the stock distributor with an aftermarket unit that is not emissions certified
* Modifying, removing or replacing the stock computer or PROM chip with a non-certified component
* Blocking the heat riser duct under the intake manifold
* Knocking out the filler restrictor on the fuel tank inlet pipe
* Replacing the stock non-vented gas cap with a vented cap
* Removing or disconnecting the fuel vapor recovery canister
* Changing the idle mixture or stock carburetor jetting
* Removing or modifying the carburetor choke
* Modifying or replacing the carburetor accelerator pump with non-certified components
* Installing an intake manifold or racing manifold that lacks provisions for the stock EGR valve and/or a heat riser duct
* Installing a carburetor that lacks the stock emission hookups
* Installing non-certified fuel injectors
* Installing a long duration "racing" cam that is not emissions-certified
* Installing exhaust headers that lack provisions for a heat riser valve, an air cleaner preheat stove or fittings for an oxygen sensor (if required)
* Installing valve covers with open breathers or no fittings for a PCV valve
* Installing any induction, fuel or ignition system component that is NOT emissions legal
You know what they say about people who live in glass houses.
well i have done just about all of them things and so have 90% of the members on here have atleast one of the things done
anyway i can say that i got more MPG and a little more power getting rid of my cat.....but o well
Old Feb 25, 2009 | 06:55 PM
  #52
Tice's Avatar
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
Well, 90% of all of those things above are done to most any and all race car, so... what? Do Race cars not give off emissions? What's the difference between Emissions from 200 Race cars goin 100+mph in a circle or down a strip, and 200 street cars sitting on the interstate or 35mph in a Neighbourhood? See what I'm sayin'? Despite these stupid laws, the 'Ozone' or w-e is still "in danger"...
I think it's all BS, but... I have to conform to the Laws these crippled old men throw at us anyways... but, Evidently, if you're racing, you don't...
Old Feb 25, 2009 | 07:02 PM
  #53
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 89ROC-Z
Who is monitoring all the forums on the internet to look for any "illegal" activity?
How would TGO get "shut down"?
Im a member on hardcoresledder.com and so is IHI with the red firebird doing a wheelie in his sig, they talk obout everything on that site, even unregstered illegal firearms, and nothing has happened, so how could anything happen?
You need to keep up better with current events.
Old Feb 25, 2009 | 07:06 PM
  #54
five7kid's Avatar
Originally Posted by redfbody
Im sorry i started this thread. Mods please except my apologies.
Eh, happens all the time. Just
If you really want to start the flames, post something like, "I want to stroke my 305 to a torque-monster 335 and remove the cat and all that smog crap. Which synthetic oil should I use?" That'll get things hopping.
Old Feb 25, 2009 | 07:09 PM
  #55
Tice's Avatar
Lesson Learned!
Old Feb 25, 2009 | 10:10 PM
  #56
redfbody's Avatar
lol lol lol lol lol Now thats funny!!!
Old Feb 25, 2009 | 10:40 PM
  #57
jdlgt90's Avatar
Car: '82 Z28, T-Tops, White
Engine: 305 4bbl
Transmission: 4 speed manual
Axle/Gears: stock as a rock
From NYS DMV Brochure on Emissions inspection....
Some vehicles are exempt from the emissions inspection program: Your passenger car or light truck does not have to be inspected for emissions if it is:
  • Less than two model years old;
  • 26 model years old or older;
  • Registered with historical plates; or,
  • Electric-powered only.
So my '82 is exempt.....needs to pass safety only
Old Feb 25, 2009 | 10:48 PM
  #58
Stephen's Avatar
Car: 87 GTA
Exempt from TESTING part only, or 100% exempt...Meaning you can just rip off all the FEDERALLY REQUIRED equipment?
Here in TX, I know we're exempt from TESTING, after 24 years, but it doesn't mean the stuff cam simply be removed. It still has to BE there, just no more sniffer test.
Or like me....I moved to a non-emissions test county.
Old Feb 25, 2009 | 10:54 PM
  #59
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Integrity, even if your car is not going to be checked, you should do whats right by keeping it environmently safe. They rely on your honesty to keep it clean.
Old Feb 25, 2009 | 10:55 PM
  #60
jdlgt90's Avatar
Engine: 305 4bbl
there is no sniffer test in NY(there is in NY City, but not the rest of the state), they plug the computer into the OBDII socket, if you have a check engine light on, or all the monitors are not set, the vehicle fails.
And who is going to enforce these "Federal" emissions laws?
ive never heard of anybody getting a ticket citing any kind of Federal emissions law.
Old Feb 25, 2009 | 11:02 PM
  #61
Stephen's Avatar
Car: 87 GTA
I never implied anything was OK to remove. I'm not even required to be tested, but my car is CLEAN.
2 years ago was my last emissions test & they were scratching their heads & commenting how CLEAN my 20 yr old (emissions results) were.
Old Feb 25, 2009 | 11:14 PM
  #62
89ROC-Z's Avatar
Car: 89 IROC-Z
Dont worry im not taking it that you said removing things is ok. I think you should be able to do what you want with your car, but as long as you keep the emmissions at or below standard, you should be able to remove/add what you want.
For example,you remove AIR, but still have a cat, and you test emmissions and pass the sniffer or whatever your good to go.
Cut the visual inspections, just take the readings from the tailpipe and if they're good, your good. Im confusing myself too lol
Old Feb 25, 2009 | 11:27 PM
  #63
Stephen's Avatar
Car: 87 GTA
No.....You make perfect sense. My wife tried to get changes made to the emissions testing here in TX, when she was the "semi-big cheese"....She wasn't a big ENOUGH cheese to get any changes made.
But your right.....If the TRUE goal (not to raise revenues) is to get clean air.....Why even open the hood? Stick the sniffer in...Pass or Fail...Simple as that. It shouldn't matter if you have the "correct" engine & equipment, or a roots blown 572 big block sticking through the hood. As long as it passes...Put a sticker on the car...NEXT!
That's always been my biggest gripe about testing...The deetails of HOW you can pass.
I knew a guy once that had a single cat 3rd gen....He swapped to an OEM dual cat set-up. But it wasn't even available on his car (like a '85 or something.....wrong year).
Anyways.....
He passed the sniffer, but was denied the sticker, because of "illegal equipment".
So he went home, put the stock single cat back on, got retested.....
Sniffer #s went UP, but still under the limit.......
You guessed right. He got his sticker, even though his car was WORSE output!
Now THATS F'ed up! Pass people by making their car worse.......
BTW....When I got my car, the smog pump was totally disconnected. Not even a pulley on it. Still passed.
Old Feb 26, 2009 | 06:47 AM
  #64
KNT_RDRaz's Avatar
Car: 1991 KITT vert
Engine: SBC
If i delete my cat will that make the exhaust louder?
I dont have to worry about state emissions since i live in Alabama.
Thanks Matt
Matt to answer your question, Yes your exhaust will be louder.
As for the first few that replied initially, remember, simple and
straight to the point is usually the best way to avoid all out
flame wars.
~nough said.
Old Feb 26, 2009 | 01:15 PM
  #65
five7kid's Avatar
The very question, which you quoted, contains a statement which implies something that is incorrect. State emissions aren't the issue, Federal law is.
Setting the record straight does not a flame war make.
Old Feb 26, 2009 | 02:12 PM
  #66
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Ok we have seen just about every kind of advocate for removing the pollution control equipment and every tree hugger is up in arms telling everyone that it will save the world by keeping all the emissions installed. Hmm!!! my exhaust consists of hookers 2210's to a mufflex y pipe to a 4 inch pipe w/ NO CAT'S to a spintech exhaust. It has no exhaust restrictions and no power loss. I only got 10mpg before and hasn't changed since the new engine.. So what about they synthethic oil anyway??? LOL.. I think we have beat this subject to death.
Old Feb 26, 2009 | 05:56 PM
  #67
89RS_82Z's Avatar
OMG just lock this post LOL, his question has been anwsered, yes it will be louder
Old Feb 26, 2009 | 06:40 PM
  #68
five7kid's Avatar
Tree hugger? Me???
Not hardly. . .
Old Feb 26, 2009 | 07:05 PM
  #69
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Originally Posted by 84 z28
hate too tell you but back pressure isnt your friend the less you have the more power you make. Thats exactly why upgrading your exhaust system increases power and fuel economy less restriction.
actualy backpressure is nessicary on most stret cars to optimize efficincy, YOU WILL MAKE LESS POWER ON A OTHERWISE STOCK ENGINE IF YOU GO WITH STRAIT PIPES/ OPEN HEADERS.
now if your engine has an aftermarket cam with a tighter LSA and more duration, yes, it will help to relieve backpressure.
Old Feb 26, 2009 | 07:48 PM
  #70
KNT_RDRaz's Avatar
Car: 1991 KITT vert
Engine: SBC
This looks like a job for moderation~~~~~
Old Feb 26, 2009 | 09:26 PM
  #71
89ROC-Z's Avatar
Car: 89 IROC-Z
Or Andy, he's the one that actually controls things around maybarry
Old Feb 26, 2009 | 09:34 PM
  #72
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ok, I'm seriously going to make a sticky and close all cat threads from now on. This is getting ridiculous.
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
gta power
Aug 13, 2015 06:15 AM
drathaar907
Aug 6, 2015 04:20 PM
