finally a sound clip
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
well i finaly got a chance to go and finish my y pipe for my lt's given im not 100% satisfied and i may redo it again it serves its purpose. here are some pics of the y and i pipe. it still needs to be cleaned and painted though. it was also done with a flux core and the car at ride height. setup is hedman lt's 2 1/2 off each header into a single 3.5in i pipe with cutout then 3in over axle into a stock 2002 ls1 trans am muffler.
video
pics
video
pics
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
re: finally a sound clip
looks like it hangs a little low, any problems with ground clearance
hangs a lil low not bad though i still need to tweak it some i had it tucked a bit better.the car has a short tire on it and has very worn suspension too so that is working against me.
