Long Tube Question
Car: 87 Camaro
Engine: 5.7 350 TPI
Long Tube Question
i want to instal some new headers on my car. I do not have many upgrades to the engine if any at all. I was thinking of getting the hooker 2055s for my 350 with the air tubes. The air tubes is what I'm questioning. If I went with the long tubes will not having the air tubes hooked up cause any real problems with the engine. I would like to keep the ecm for the tpi system functioning correctly because no one likes a check engine light. Any input helps thanks.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Long Tube Question
The Hooker 2055's are much easier to install than long tubes are. They're also better made to fit with the rest of your exhaust.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I was going to the 2055's and finally opted for the 2210 Long Tubes. You won't be disappointed and you won't have to modify as much as I did to get them in.
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
from the performance angle I loved them BUT.
ground clearance was always an issue, and you had to bend a little bit of the header tube in one area to clear the spark plug.
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
for the people with 2210 hooker headers how much did you pay for them and where did you get them from?
Car: '82 Z28
Got mine from Summit, they're listed at about 520 bucks. Found them to be very easy to get in and out of the car, through the bottom.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
What's your budget? You're also looking at needing a y-pipe custom built.
I'd go with the 2055s.
With the way your car sits now, you're not going to gain anything that worth the the extra difficulty of getting the 2210's set up on your car. The 2210s are only going to be worth the hassle if you plan doing some serious upgrades (heads, cam etc) and going to the track.
With the 2055s, you can drive your car in the garage, install them, and drive it out of the garage in a few hours.
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Car: 87 Camaro
Engine: 5.7 350 TPI
yea im going with the 2055s. the ones at summit for 520 or whatever. they are not coated so would it be necessary to get them done or will they be ok in there with some exhaust wrap or something like that. its a big difference between the 800$ ones and the $520 ones.
Engine: 400
If you can swing it, I'd get them coated. They will run cooler, not rust and look A LOT better.
Car: 1987 IROC-Z
