Only thing holding me back :(!!!
Old Mar 8, 2009 | 11:41 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Alright, so I'm getting my 350 rebuilt and it will be done this week, only problem is I can't find the right parts for my exhaust. I'm planning on using manifolds (I know I know I should be using headers but I had some shortys and they rubbed my frame so I thought it would be easier to use the manifolds but....) but I can't find the y-crossover pipe for the manifolds I can only find it for the headers. Can anyone suggest something for me or where I can look? Or am I screwed and should just find some headers that will work. I don't wanna use headers cuz they really sucked before and I'm afraid that even if I get some long headers or some that may be better quality that they will still rub or that I will have a problem mounting them on the block. PLEASE help... this is the only thing holding me back from getting my car done.....
-G
Old Mar 9, 2009 | 01:24 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Only thing holding me back :(!!!
what design header did you have that rubbed the frame? even the cheap flowtechs don't have rubbing issues, i'd say get some dyno don headers. more than likely if you were rubbing the frame you had worn out engine mounts, replace the mounts and try again. there was a company that sold the stock y pipe for manifolds i saw it in summit i believe the brand was pypes, but i still recommend to try headers with new motor mounts.
Old Mar 9, 2009 | 01:36 AM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
I honestly don't know what brand they are or design. I just know they were shortys. They came on the car when I bought it. The motor mounts aren't worn out. Neither sags or looks to need replacing.... so I'm not sure yet. Thanks for the suggestion though
Bob88GTA
Aug 18, 2015 03:31 PM
johanlindgren
Aug 16, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
