CODE 54 (EGR Issue)
Old Mar 27, 2009 | 10:02 PM
1HotZ28&SS's Avatar
Car: '11 Explorer Limited
CODE 54 (EGR Issue)
Guys, I replaced my Valve covers with supposed OEM replacements on my 86 Z28 and Since then I'm throwing code #54 (EGR). I guess these valve covers are slightly taller the the true OEM ones and thus causing a vacum leak. I built up a little layer of Mr Gasket between the top of the intake and the Base of the EGR but I guess it has not done the trick. Any Idea's ? I guess I'm really looking for some sought of spacer !
Old Mar 31, 2009 | 11:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: CODE 54 (EGR Issue)
Code 32 is the EGR. Code 54 is the fuel pump circuit. There is a list of the codes in the technical data section linked from the main page of this website.
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
