Ground Clearance
Old Apr 3, 2009 | 08:20 AM
Jeff_Sheeler's Avatar
Car: Camaro
Ground Clearance
I know there were a few threads below where the big issue was ground clearance. I was searching for a solution and I think I might have found one. Has anyone ever considered oval pipes? Here's a link to one website I found https://www.drgas.net/catalog.php?catid=3
Old Apr 3, 2009 | 01:35 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Ground Clearance
I considered it a long while back. Only problem is, it still wont let you run it under the floor boards or anything. In fact...there was less room for it. I have my pipes tucked up and also tucked in side to side. There just isnt much room under there. Its also expensive. And you have to get round to oval adapters for both your headers and for your catback or mufflers.
If you build a nice tight system though, and plan it out well, ground clearance isnt an issue. Im not sure what kind of exhausts you were checking ground clearance issues with, but Im running long tube headers, mandrel y-pipe, flowmaster merge, to a magnaflow cat back. My car is lowered over an inch all around, and I take speedbumps with no problem.
Key is to tuck it on up. And build/buy a nice trans crossmember that will let you put the exhaust up higher. Its alittle easier for the manual guys also, because the trans area isnt as wide.
Exhaust is fun....haha.
J.
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Thaney9
Oct 24, 2015 07:26 PM
91 SrS
Oct 7, 2015 04:32 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
