Headers
Old Apr 7, 2009 | 12:31 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Headers
Alright, I will have enough money in about a week for this, so how does this sound for the header set up?
Headers
http://www.jegs.com/i/Hooker/520/2055/10002/-1#
Header gaskets
http://www.jegs.com/i/Percy%27s/760/66011/10002/-1
Locking header bolts
http://www.jegs.com/i/Stage+8/868/8911/10002/-1
Spark plugs
http://www.jegs.com/i/Accel+Spark+Pl.../276S/10002/-1
Spark plug wires
http://www.jegs.com/i/MSD/121/5570/10002/-1
Any feedback is appreciated
Old Apr 7, 2009 | 03:40 AM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
Re: Headers
the headers are a good choice
idk if those were the same plugs i ordered. but i did get the shortys as well
the wires - if possible if you can afford maybe a little more expensive set and or if you plan on running it under the headers for a cleaner look get the universal kit or a kit from a 90s truck i think.. also u need 90* angle plugs
the gasket looks good
Old Apr 7, 2009 | 12:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Headers
Why does he need a more expensive set? The Borg Warner CH8833 from the local auto parts store are the same price and I've had a lot more good luck with them than any set of MSD wires. The Borg Warner's are made for 87-95 Chevy Trucks, are 8mm, have all 90* boots, and have a low resistance for more voltage.
Old Apr 7, 2009 | 02:17 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Headers
What's the part number on those wires kevin?
Old Apr 7, 2009 | 03:54 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Headers
noob question real quick, what are "*90 plugs"? are you referring to 90 degree boots? If you look at the picture of the spark plug wires i posted you'll see that the boots are at a 90 degree angle.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
