dual exhaust and header type
Car: 85 camaro
Engine: sbc 400 .30 over
Transmission: 700r4 with bm shift kit, 2200 stall
Axle/Gears: 7.625 10 bolt posi
forget it
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
re: dual exhaust and header type
That is the cheap way, if you want it done right, there is room to run 2 - 2 1/4" pipes along the same route as the stock 3" pipe and than you stack the muffers in the original muffer spot, the only draw back is the exhaust only exits one side with duel outlets.
Eric
Eric
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
IMO, it's just better to run two 2 1/2" pipes into one 3.5" pipe, yeah it'll be only one tailpipe, but the flow is so much better than a bunch of bends and glasspacks (which flow the worst of any muffler believe it or not, a 2 1/2 straight pipe flow something like 700 cfm, with a glasspack it flows like 180cfm..bad)...but everyone likes to try thier own thing...props to you for trying something different...
Car: 85 camaro
you know what a glasspack is right. a straight pipe inside another pipe and fiberglass packed between the two with little holes drilled in the inner pipe. there is no restrictions.
Re: dual exhaust and header type
Glass packs are restrictive. The only mufflers that really flow well are race mufflers like moroso spirals and dynomax bullets. And just to add to this I have true dual exhaust and 2 1/2 pipe and my mufflers are right behind the transmission. I have good clearance and never scrap anything.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
how much hp? you can get plenty of power out of a single pipe and not comprimise clearance and drivability, IMO.
im a firm believer in single exhaust(to an extent)
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
This kid is . A 500 hp 305? Oh thats right, our kohler powered lawn mower has 1000+ horse power!
1 Post
Engine: L98 494hp
According to the muffler flow chart I have....the worst flowing exhaust muffler out there is a glasspack....yes I know how a glasspack is constructed..but it's not just if you can see through it that makes it good....the air turbulance in there is severe, not smooth....plus there is this little thing either people forget or don't know about, reverberations of sound bouncing back up to the motor.....good mufflers, like the max flow, not only run the exhaust air smoothly through, but are designed with sound reverbs in mind....if you want I'll find the muffler flow chart and post it.....let me look for it..I'll post when I find it on my computer again
1 Post
Engine: L98 494hp
Here it is...read numbers close...notice max flow muffler has no restriction, and notice how much glass pack has...
Car: 85 camaro
i joined this forum thinkin there were gona be some gear heads and not a bunch of dumb ***** but i guess i was wrong. ****en morons
Car: 85 camaro
hey 89iroc-z **** you
i have true duals, 2 1/2 inch with dynomax super turbos. i had this exhaust installed when i was running a very mild 350 and it sounded great and performed well. it is a side-exit exhaust setup and i rarely have ground clearance issues. but the shop had my car for a few days so they could do a nice job with a custom system to fit, look, and perform well.
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
definitely sounds a little sketchy, and rigged up. but everyone does what they want.
1 Post
Engine: L98 494hp
AND now since were getting all pissy about things, I will bring it up.......a 500hp 305.....really!?!?!
I'd really like to see your list of mods and the dyno sheet, if you have one....at least a list of mods though. Cause if you're actually getting 500 horse I'd like to copy you build, but I doubt it. If you're going to post something you have to expect people who will not like what you have to say or what you did.......that's why others read threads and see different thoughts on subjects.......
Car: 85 camaro
the only thing im getting pissy about is arguing about them gasspacks, you one them people who been calling them restrictive,they are the most free flowing muffler on the market(them mufflers on them rice burners are pretty much a glasspack so im not considering that), and yes i know straight pipe is less restrictive than a glasspack ,but im not talking about straight piping. i let a muffler shop do my setup he told me it was " THE BEST WAY TO RUN DUEL EXHAUST" besides the fact, i didnt say i know everything. i know how to utilize, i know how to make **** work. and about the hp, the motor is making about 500 but im getting 465 to the wheels. now lets quit argueing about them glasspacks its a stupid arguement.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
depending on a "glasspacks" core, some of them flow well, and other slow like CHIT.
This forum is a place to educate yourself about Thirdgens. Not everyone is on the same knowledge level. There is NO reason to bash anyone or name call. No one here was born knowing about cars. You've got to learn somewhere and ask questions. So be polite, and try and help each other instead of making sarcastic comments.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
