Exhaust Diameters
Old Apr 25, 2009 | 02:28 PM
havoc85's Avatar
Car: 1985 Trans Am
Engine: 5.0
Exhaust Diameters
Hello all
I have an 1985 Trans Am 5.0 5 Spd with the 4BBL(code H LG4 I think).I have had the carbs rejetted and the cam for the HO installed and a 3" SLP catback system.This car has been stored for the last 10 yrs but i start it and drive it every 2-3 mnths to keep everything moving and had it coated in oil to try and keep the rust at bay.the other day while i was tending to it I noticed that when I started it it was running kind of rough so i proceded to put some carb cleaner and rev it up a little.Then i noticed smoke coming from the back of the motor WT>>>.Any way my catylic converter was cooking itself bright orange so i shut the car off and let it cool down.So Long story short it looks like I need a new cat..what I need to know is the diameter of the pipe from the Y to the cat..I have 3" after the cat but needed to use an adapter pipe to make it fit..if i get a 3"in-3" out hiflow cat will it work..any advice would be greatly appreciated.
Old Apr 25, 2009 | 04:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Exhaust Diameters
https://www.thirdgen.org/forums/exha...-question.html
JamesC
Old Apr 25, 2009 | 04:38 PM
havoc85's Avatar
Car: 1985 Trans Am
Engine: 5.0
that link shows.....
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
so what your saying here is the y-pipe to the cat is 2 1/4 "
on my vin-H car
is that right??
can the vin-G manifolds fit on the vin-H motor just by bolt on or do the heads need to be changed
this would give me a 3" y-pipe to a 3" exhaust im guessing
Old Apr 25, 2009 | 04:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The LG4 and L69 heads are exactly the same thing.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
zapr
Jul 27, 2018 06:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
PurelyPMD
May 5, 2016 04:57 PM
david068513
Sep 18, 2015 10:36 AM
