leaking exhaust manifold help
Old May 17, 2009 | 02:18 PM
don_11's Avatar
i have a 89 camaro with a 350 bore over 30 roller cam 501/501 my passenger side is leaking bad and its also skipping and i just changed my plugs im wondering if theres any relation in the manifold leak and the skipping any ideas its skipping bad and its annoying
Old May 17, 2009 | 02:51 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: leaking exhaust manifold help
no. did u gap them correctly? is it carb or tpi tbi??? more info would be helpful.
Old May 17, 2009 | 04:01 PM
don_11's Avatar
they came pre gapped and i have a edlebrock carb with a 1 inch spacer on it
Old May 17, 2009 | 06:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
leaking exhaust manifold . do you have stock manifolds or headers ? in any case install new gaskets , retorque & tighten from the center out . on the miss , did you drop any of the plugs . could be a bad plug or bad plug wire . i would lean towards the plug wire . an old plug wire can break down just by handling . OEM type wires ( carbon core type ) start to deteriorate from the date of mfg. . new may not be new , may have sat in a warehouse for 4 or 5 years . worse yet they may have been made in CHINA . a good set of wires like MSD , ACCEL , or TAYLOR is a good investment . good luck .
Old May 18, 2009 | 09:46 AM
berlin305's Avatar
Yea that is right check the wires out. Also when is the last time u check the distributor cap??? might be cracked or the coil pack assuming you are vacuumed advanced like me. i have edelbrock with a performer edlebrock manifold. accel distribitor. just check little things like that. Wouldn't hurt to just pop a couple spark plugs to check if they are ok. b/c pre gapped sometimes aren't always pregapped correctly. A fouled plug that got oil on it could do this to.
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
