modifying 2055s
Old Jun 6, 2009 | 03:26 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
modifying 2055s
i found a set of brand new 2055s with in ten miles of my house on craigslist for 175. so i originally did not want all the air tubes and didnt want a cat but for that price cmon. now can i just plug the holes for the air or cap the main one off. also sisnce its a 3 inch y pipe will it just bolt just to my magnaflow or will i need to buy a pipe for in place of the cat, what should i use in place
Old Jun 6, 2009 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: modifying 2055s
you will need a section of pipe to replace the cat if you are going cat-less. Which is illegal in all 50 states. Seriously, a good high flow emmissions legal cat will not cost you much power at all, and the car will not smell.
as for the air tubes, the thread holes in the headers can be plugged, i think its pipe thread.
Old Jun 6, 2009 | 08:50 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: modifying 2055s
what do you mean the tread holes. those tubes arent welded on there threaded pipes?
Old Jun 6, 2009 | 09:03 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: modifying 2055s
buy them immediately - especially if they are new and clean.
leave the smog stuff on it - you might need it later. just cap the air tube and use the o2 sensor if your computer needs it.
Old Jun 7, 2009 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: modifying 2055s
ha! sorry i was thinking about the stock manifolds.
I would pick them up.
Old Jun 8, 2009 | 03:38 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: modifying 2055s
i went there today and this spoiled little ****er sold me everything in his house. he gave me the coated hooker headers and y pipe brand new for 150. an aftermarket water pump for 25 he said it cost him 160 and a set of 4 tires for like 80 $$$.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
