Back to the third gen stuff.
Old Jun 26, 2009 | 05:30 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
Alright guys i can't afford headers at the moment but i need to fix my exhaust so i can drive my Z again. I cut off the flowmasters since i discovered a v6 sounds just like my v8 with them so all i got is a real loud straight pipe. What i want to do is cut the ypipe before the last bend where it goes into the cat so i have a paralell pipe to the side of the car. then take a section of 3 inch tubing and connect it the ypipe and run it down the side of the car into like a dynomax bullet, then use a turn down tip but angle it out the side instead of on the ground before the rear tire. I think i can use some of the flowmaster tubing since its 3 in. The bullet is roughly 45 at summit,clamps of course, think i got a 20.00 off thing somewhere though. Ok so cost wise unless i'm forgetting something it seems pretty cheap to do.
Now i would like some advice and opinion from everyone, if you reccomend a different size tubing, muffler, ect. Just keep the cat opinions to yourself i'm not running one.
this is a little shot of what i got rigged up right now.
Old Jun 26, 2009 | 07:40 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Re: Back to the third gen stuff.
Sounds like some ill advised backwoods engineering.
Fail.
Old Jun 26, 2009 | 08:28 PM
Miles87Z28's Avatar
ok. Anyone else. Trust me the car isn't worth the money of a full cat back and its not a daily driver by any means.
Old Jun 26, 2009 | 08:54 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Dude i plan on doing the same kind of thing. I was going to put a cut out right in front of the cat and keep the extra pipes hidden under the car. just cuz of the sound police lol
Old Jun 26, 2009 | 09:38 PM
Miles87Z28's Avatar
All i'm going for is to quiet the sound down slightly, but mostly clear it up to an even tone. Most older cops can appreciate a good sounding car, its when they're anoying you get into trouble. Just can't get on it if a cops on my passenger side with this set up.Lol.
Fast355
Dec 2, 2016 06:33 PM
Omega
Oct 1, 2015 02:20 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
