Need Exhaust Help
Old Jun 30, 2009 | 08:25 PM
436efi's Avatar
Need Exhaust Help
I currently have the Mufflex setup with the 3" Y into a single 4" pipe over the rear into a Magnaflow 4" muffler. I want to run a Spohn Torque arm and relocate to the crossmember, but this will interfear with the exhaust. So does anyone make a true dual exhaust for a 3rd gen? Any exhaust out there better then the Mufflex setup?
Old Jul 3, 2009 | 02:03 PM
brutalform's Avatar
Re: Need Exhaust Help
Hey Rob...One of the reasons why I never went with the Spohn arm was the exhaust. I believe you can get a system made from the collectors on back, just as the "Y" pipe runs now, back to the rear end, and just put mufflers and turn downs there, right before the rear. The only thing is I believe it will not pass PA inspection with it that way. I do not know your intentions with the car. BTW, killer videos you posted on the racing board!!!
Old Jul 4, 2009 | 01:45 PM
436efi's Avatar
Thanks Tom, do you know who makes it, or just better off going to a Exhaust shop. Just wanted to know if its possiable to run dual's on a 3rd gen
Old Jul 4, 2009 | 11:52 PM
brutalform's Avatar
I've seen lots of pics on TGO of "true duals" on third gens. If having the mufflers under the car with turndowns is not a problem for you,(right before the rear) I'm sure a shop can build you what you are looking for. If they would just continue the design of the Mufflex "Y" off of the collector and continue it down under the tunnel, making sure there is no ground clearance problems as they go it can be had. I"m sure a GOOD exhaust fabricator can do a nice professional job. Maybe not a job for your TYPICAL exhaust shops though.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
