Hooker/Doug's general review and y-pipe documentation
Old Jul 13, 2009 | 03:39 AM
1bdbrd's Avatar
Car: 1991 Trans Am
I figured I would throw this up here since there really wasn't much help when I was looking for something like this. I am installing the Doug's long tubes into my car along with a T56 and figured I should go for the best possible y pipe design that I could. I don't think this will work with an auto because of clearances around the sides of it but I am going to be using a Skulte t56 swap crossmember to make ground clearance as good as I can get it.
Parts used were a 3" dual inlet, 4" outlet Flowmaster merge collector (work of art IMO) and a set of 3" Hedman s extensions. All total I have around $80-100 in this setup total and it damn near fits without ANY modifications at all. It will take some and I will document that when its time. On to the pictures...
Comparing old (hedman 2-2.5" y to new custom y)
Showing just how much bigger the outlet is between the two..
One more comparing the overall size difference..
Any questions, comments or concerns?
Old Jul 13, 2009 | 03:12 PM
Demon355's Avatar
Re: Hooker/Doug's y pipe design (Pics inside)
Looks nice! Get them installed pics up!
Old Jul 14, 2009 | 01:21 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yeah thats gonna be RIGHT down the middle of your car under the drive shaft and tq arm, i think your gonna need to make some modifications
Old Jul 14, 2009 | 03:10 AM
1bdbrd's Avatar
Car: 1991 Trans Am
That's where I planned on it going. I want it to run pretty similar to the 4th gens instead of all over the under side of the car.
Old Jul 14, 2009 | 03:22 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well i hope it works out for you, i need to do a y pipe for my long tubes so this may be the ticket depending how it turns out. be sure to post up pics when your done!
Old Jul 14, 2009 | 03:33 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Honestly it shouldn't be a problem. Ground clearance will suffer some but I have dealt with that for years so its really nothing I'm not used to.
Also, I realize that the setup isn't going to stay that simple in order to fit through the crossmember but figured I will post up before and after shots.
Old Jul 14, 2009 | 10:33 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I've been trying to do something similar with the Dougs Long Tubes, cats and an X pipe, and for space and ground clearance, plus the best balance, right down the middle is really the best place.
TA
Old Jul 14, 2009 | 10:59 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I've got a setup a lot like that.... but I decided I wanted a dump at the axle so my ground clearance isnt great at the back of the car, but I can always run it over the axle later. For now I like the dump. The whole system is pretty much even with the front subframes which is pretty much even with the collectors. The 3.5 inch single pipe at the back takes about a half inch away from the ground clearance (dual 2.5's into a single 3.5) but that's not a big deal if you just tuck it over the axle.
You can see from the side where the dual 2.5-3.5 collector pipe starts.
I dont see why you'd run it down the middle with the torque arm right there, though?
Old Jul 15, 2009 | 03:22 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Actually by middle I meant pretty much what you did. Looks like I might need more piping though? I didn't think about the transmission being so long...lol. I wonder if I can buy just one hedman s extension? Sucks that the best shop around for exhaust work doesn't have a mandrel bender..
Old Jul 16, 2009 | 10:33 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Ok so after working around them today I figured I would post up some better thoughts on the headers themselves. They look amazing, MUCH better than any coated header I have ever seen actually. I did have to finish cutting the #8 primary off since for some reason the cut through the flange wasn't finished. No biggy though.
They literally slipped right and and if I had to do it again, I will drop the transmission. Made the job MUCH easier. I might have to pull the passenger side and grind like in the 2210 install thread because it just does touch.
Plug access is not bad. However, with a gear ratchet I was able to get all the spark plugs on the driver's side. I didn't try the passenger side but they should be accessable with some work.
WELL worth the money, especially since they are a couple hundred cheaper than the Hooker 2210s for the exact same product.
Old Jul 20, 2009 | 12:42 AM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Re: Hooker/Doug's general review and y-pipe documentation
i was planning on doing the exact same y pipe design for my iroc with my hokker lt's. im jus about to order everything for it from jegs. how'd it work out for you so far? any problems? need some feed back bro, thanks
Old Aug 17, 2009 | 03:59 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Wow, sorry I didn't see your post until now! Everything that I got worked out pretty well actually. The 2 s extensions that I got from hedman actually put the merge almost exactly at the back side of the transmission crossmember. They don't fit perfectly but can be bolted into place. I will be leaving it up to the exhaust shop to finish it up so I will take pictures once they get it welded.
BTW, another option for extensions might be this kit from Flowmaster:
http://www.summitracing.com/parts/FLO-15908/
You get really more than you need but this would probably allow you to put the merge where ever you wanted it under the car. Mine will need more piping for sure since its right where the driveshaft enters the transmission so I don't think I can put the merge there with good enough clearance. One thing is for sure, this will cut a LARGE portion of my intermediate pipe off. Basically all that will be left of it is a piece that is a little shorter than the driveshaft.
Old Aug 30, 2009 | 12:50 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
since i saw that you did you own y pipe would you do one for my hooker 2055
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
