ceramic coated guys (help)
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
I going to get my hooker 2210's ceramic coated in a few days. I was wondering what to do about my header bolts, do they coat them also or do I need to get stainless steel ones? I just dont want to put ulgy black bolts on my shiny new headers!
Thanks, Jerrod
Thanks, Jerrod
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: ceramic coated guys (help)
I got some Breslin bolts... they torque down and then lock with an allan key in the middle... I prefer this style to the Stage 8 locking ones, to many pieces for my liking... They have black and stainless...
Raf
Raf
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
your problem is the same as many of us . ceramic coating is great , but it does/can scratch . what i have done in the past is S/S bolts & washers . you will have to grind a flat on each washer . the flat will go against the area of the exhaust tube . washers are stamped out of sheets of metal , one edge is pretty smooth the other has a rough/sharper edge . if you have a grinder one side may have a wire wheel . a wire wheel works great for smoothing rough edges . put the smooth side against header flange . go slow , take your time and you can end up with scratch free headers . good luck .
Car: 89 camaro
Engine: 383
I just orderd percys s/s locking header bolts! I will do what you said Uncle... I have a dermel tool that should work well.
Thanks for your help guys!!
Car: 92 Z28
Engine: Boosted LSX
quoted for truth ! I have the Stage 8s and Will never spend the $$ on them again. to get the lock washer on you have to have the bolt in just the right spot. if its not you have to try and tighten it a little more or loosen it. I ended up having to grind some of the lock washer more.
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
They make a ceramic spray coating for stuff like bolts or touch up....I bought it locally at parts store.....I also have ceramic headers, and ended up touching those up with it but also I bought a few cans and coated the whole exhaust system front to back....looks great!! Just an idea for ya
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Sep 8, 2015 03:38 PM
