Question about header-to-y-pipe gaskets on hedman shorties
Old Jul 30, 2009 | 02:11 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Hi,
I bought a set of used hedman headers with y-pipe.
Can someone confirm if the correct gasket to use between the header and y-pipe is a flat 3 bolt flange gasket?
I tried using a doughnut type gasket and I think this was a mistake. I assumed they were made for the doughnut style...but the flanges are now warped. I need to get this figured out.
Thanks for any help!
Clem
Old Jul 30, 2009 | 03:55 PM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
Re: Question about header-to-y-pipe gaskets on hedman shorties
I just installed a set on my 86 IROC and there is no gasket between the collector and y pipe..that is provided your collector / y pipe is the "ball & socket" style.
Old Jul 31, 2009 | 09:27 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Mine are an older set with a 3-bolt, 3-inch flange. (not the current style ball-socket. I WISH I had that style!)
Can anyone with an older set of Hedmans confirm which type of gasket they use?
Thanks,
Clem
Old Aug 2, 2009 | 11:04 AM
5speed's Avatar
Car: 86 IROC
I'd be willing to bet it takes the flat style gasket then.
Old Aug 2, 2009 | 01:05 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Mine aren't all that old (4-5 years at most) and have a 3 bolt flat flange I believe.
Old Jan 21, 2010 | 12:27 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Thanks,
Clem
Mr Gasket Ultra Seal # 5971: 3" collector diameter, 3-7/8" bolt circle diameter, 3/8" bolt hole. bolt length 1.5 inches. Just replaced mine, previous mechanic had most bolts in not-reachable positions. even with a open/box end wrench. Ended up bending the flanges so they don't seal well. Make sure the flanges are straight or level all the way around...
hectre13
Sep 8, 2015 03:38 PM
Chiknhawk
Aug 23, 2015 05:54 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
