EGR valve question
Car: 91 Formula
Axle/Gears: stock
EGR valve question
Will an EGR valve off a 91 350 TPI work for a 305? I'm having a hard time figuring this out. NAPA says there is two different models for my 91 Firebird 305 TPI, but they don't know the difference between the two. They say I need a certain number off the valve itself, which I obviously can't see with the plenum on, and I'd rather buy a used one anyhow. But I don't want to buy one made for a 350 and have it not work, since there seems to be a few different types out there.
Thanks for the help
Thanks for the help
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: EGR valve question
Only way to know for sure is to take off the one you have. Some are labeled negative, some labeled positive, and I'm not sure there's a definite way to determine which engines had which one.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
