97+ vette exhaust on third gen?
Old Sep 10, 2009 | 09:53 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. I'm going to be doing an LSx swap in my 86 TA soon and was just thinking, the sweetest sounding LSx powered cars by far are the vettes, and I was curious if anyone has thought about or seen this swap done yet? I'm sure the mufflers would fit in there nicely. You would just have to fab up a dual exhaust to them. I love the four center pipes and think they would look awesome on a third gen. I know vettes have an x pipe set up too, but the mufflers should make it sound close to a vette.
Anyways, would be cool if there was someone out there that attempted this.
Old Sep 12, 2009 | 12:13 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: 97+ vette exhaust on third gen?
Much of what gives the Corvette its different sound is the placement of the mufflers. Check out the videos of the new camaros with exhaust. They sound very similar to a the same exhaust on a Corvette.
However, unless you are talking about the bullet style mufflers that some C5 systems use, the mufflers won't fit. Plus it will be very hard to run an exhaust tip setup like they have because of our GFX and placement of the gas tank.
Old Sep 12, 2009 | 09:21 AM
Car: 1986 Trans am
Engine: 5.3 LM7
Yea custom work is always a little difficult. I'll have to go look at my car and get some dimensions. I'd love to see this done. I just wouldn't want to be out 500$ on a vette exhaust and not get it to work!
Old Sep 15, 2009 | 02:29 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Just get yourself a regular catback. It will be damn hard to get the sound you are looking for even if you do get the catback on there. Remember, they were all dual exhausts as well.
Lastly, what sound are you trying to achieve exactly? If its the sound I'm thinking of, its not a $500 catback. Its closer to $1000.
Old Sep 15, 2009 | 03:26 PM
Car: 1986 Trans am
Engine: 5.3 LM7
The fact of it being a dual exhaust is the biggest thing. I plan on doing a dual exhaust with an X-pipe on my car, but figured I'd consider vette mufflers to go for the gold. I can't stand the sound of a single pipe on a V8....just sounds too chaulky and ussually breaks up bad when shifting gears. I am a HUGE exhaust guy and feel that the final touch to a modified engine build is an exhaust to really set it off.
And the 1000$ price is probably correct as well, however I was going to consider a factory vette muffler set up because I'm a big fan of quieter exhausts. I'll have long tubes so it should have a nice rumble to it. Just looking for ideas on "different" set ups than the standard single 3" into dual crossflow muffler that GM should have ditched long ago.
Old Sep 16, 2009 | 10:32 AM
rv34's Avatar
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Axle/Gears: 3.70 9 bolt
Im sure you can find a stock exhaust for a corvette on craigslist, for cheap.
Old Sep 16, 2009 | 01:58 PM
1bdbrd's Avatar
Car: 1991 Trans Am
I am not sure where you are going to fit the mufflers on your car. The stock c5 mufflers are pretty large from what I've seen and the inlet and outlet are on the same end of the case. The gases just make a u turn in the muffler and goes out the same side it came in. Plus they won't do much for performance either.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
