Stock Exhaust diameter size
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Got a question and looked all over, whats the stock diameter of our exhaust? I need to buy another cat to pass smog and not sure what size inlet to get. Its stock with 80's series catback
SPecs on the left
SPecs on the left
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: Stock Exhaust diameter size
Being a TBI car, it's probably 2 1/4, but I'm not sure. A well opptioned car could have the larger 2 3/4. But I havent seen but a few the the larger pipe.
Car: 88 Camaro
Engine: 305 TBI
thanks, should i get a 2.50 then so it can slip over the stock pipe, or should it be welded without being slipped on?
Car: 88 Camaro
Engine: 305 TBI
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Post #4 of the following link may be helpful:
https://www.thirdgen.org/forums/exha...-question.html
JamesC
JamesC
Car: 88 Camaro
Engine: 305 TBI
Thanks James!
If i get a 2.50 that should leave enough clearance to slip the cat onto the tubes and weld? I wana make it easy for my family member who will be welding it, I had a buddy do my last one and he wasn't very good at the welding, ended up having to go buy sleeves and use them to weld the cat in.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
Above information was posted by TransamGTA350
82-83 305 Crossfire
88 350 L98 (VIN 8)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TBI and V6 engines should have come with a 2 1/4" cat from the factory. Putting a 2 1/2" cat on it will be a good upgrade.
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Best set up to go with for fuel economy and do tips add any characteristics to Fuel e or just sound ??
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
knight72
Aug 10, 2015 09:32 PM
