LS1 Swap Headers
Car: 1991 Camaro RS Stock For Know
LS1 Swap Headers
I am Stating my LS1 swap on my 91 RS and have some header questions. I am going to be running a tubular K member without spring buckets I am running coilovers with the LS. what are the clearance isues with the 4th gen longtubes.
If is is with the stock K member will the tubular one allow them to work or is the issue somewere else
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 Swap Headers
you can usually find pacesetter 4th gen headers really cheap, might be worth trying, but aside form that, the front end of the 2 cars is totally different, i would assume the frame rails are in the way.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
build your own or pony up the money for the hawks headers.
i tried to use a set of hookers from a 4th gen and it just wasnt going to work without extensive modification.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
One would think the tubular K-member with the coil overs would open up a ton of room.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It opens up room in certain areas except flow path of the exhaust. Tubular k-members do not change the fire wall or frame rail locations which prevent you from using 4th gen exhaust components (other than cat-backs; with mods)
Transmission: 4L80E/4L80E
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
