bubblies?
Old Oct 4, 2009 | 12:33 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
bubblies?
ok , so i have an exhaust leak . now my question is wher is it at ? could it be @ the haders or at the y pipe? know i read that an exhaust leak will make a car run rich " do to the oxygen sensor reading that there is more oxygen in the exhaust system" right or worng ? would the leak @ the y pipe make it run rich , or would it be a leak at the headers ? btw this is a stock 88 lo3
Old Oct 4, 2009 | 04:51 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: bubblies?
The exhaust leak would have to be upstream of the O2 sensor to make you run rich.
Old Oct 4, 2009 | 04:20 PM
Re: bubblies?
so it would be before the o2 sensor @ the point where headers meet heads , right? and since theres only one o2 sensor . an exhaust leak on the other header would not affect it right? or worng ?
Old Oct 4, 2009 | 05:23 PM
DBLTKE's Avatar
Engine: LB9, LB9
Re: bubblies?
You are correct.
Old Oct 4, 2009 | 05:32 PM
Re: bubblies?
so my leak is on the drivers side eshaust manifold ?
tom1985
Apr 19, 2016 07:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
86iroczwv
Sep 3, 2015 06:21 PM
