headers nedd help asap
Old Oct 18, 2009 | 07:12 AM
tgill's Avatar
hey i have found a camaro in the junkyard and i think it has headers on it what year camaro did they start running the smog system throw the manifold cause i have a 89 and it has it throw the headers i want to no if i might have found something to save me money i think its a 84 or 87
Old Oct 18, 2009 | 10:09 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: headers nedd help asap
very confusing post.. I think you're refering to the a.i.r. tubes in the exhaust manifolds? If that's what your asking all third gen's came factory with air tubes in the exhaust manifolds..
Old Oct 18, 2009 | 11:39 AM
tgill's Avatar
yeah im talking about the tubes that hook to manifold and i think they run back to intake or something so all 80s camaros had this smog control
Old Oct 18, 2009 | 12:34 PM
89RsPower!'s Avatar
You are confusing the egr and a.i.r. systems. The a.i.r. system runs from the air pump to the exhaust manifolds and cat conv. It only effects emissions when starting the car cold. Beyond that all the system does it take up space making spark plugs harder to change and slightly decreases horsepower (albeit by such a small amount that it makes no noticeable difference). This system was present on all 82-92 f-bodies (V8's anyway, unsure about the V6 and I4 cars).
Old Oct 18, 2009 | 01:35 PM
tgill's Avatar
yeah i understand that im just trying to figure ou if this car has aftermarket headers and the only reason i think it does is beacuse it sosnt have that shi* on the manifold
Old Oct 18, 2009 | 02:49 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The emissions tubes can be removed from the stock manifolds and plugged with pipe plugs or bolts. It is possible, however unlikely, that someone replaced the original manifolds with older non-emissions manifolds. That being said, distiguishing between cast iron manifolds and headers is just a matter of looking and seeing which it has - you really can't confuse the two.
Old Oct 18, 2009 | 04:32 PM
89RsPower!'s Avatar
you looked at the car but couldn't tell if it had headers or not
Old Oct 18, 2009 | 05:04 PM
tgill's Avatar
i looked at it it looks like headers idk how do u tell if there headers i mean the only way i no is cause they dont have that egr **** how do u tell
Old Oct 18, 2009 | 05:55 PM
RSFreak's Avatar
These are headers, do they look like this?
Old Oct 18, 2009 | 06:08 PM
tgill's Avatar
yeah they just about look like that thanks alot man u guys helped alot guess im goinig to get themm tomorrow
Old Oct 19, 2009 | 01:03 AM
RSFreak's Avatar
Great find!
Old Oct 19, 2009 | 01:30 AM
89RsPower!'s Avatar
There are no egr provisions on factory f-body manifolds. If you do end up getting a set of used headers make sure you get the matching y-pipe as well. Hopefully they are at least a decent brand, if they're something that was crappy to begin with like flow tech's don't pay more than $20 if they're in good shape. If they're rusted to death I'd avoid them all togather. Good luck! Post some pics if you can!
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
92projectcamaro
Sep 24, 2015 08:09 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
