Doug's LT's, T56, Skulte LT x-member and x-pipe.Can it be done?
Old Oct 21, 2009 | 08:31 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I'm sure someone has got to be running this combo. Car is also lowered with an Eibach pro kit. Using a 4th gen Aluminum DS and a jegster Adj. TA. I would like to use an x-pipe instead of an h or y. (unless I can be convinced differently) Also would like to run 3" pipe, car is around 450-500 RWHP that will be getting a decent shot of giggle gas. Ideas, suggestions, pics?
Old Oct 22, 2009 | 11:40 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Doug's LT's, T56, Skulte LT x-member and x-pipe.Can it be done?
Good luck finding that skulte crossmember.
I decided to go with a single pipe. Dual 2.5 equal out to a single 3.5 basically. It's easy to tuck a 3.5... 4 inch pipe will hang down another half inch... but I think it'd be acceptable if you do a good job tucking the exhaust along the stock route, up into the driveshaft tunnel and take it over hte axle. If you plan to dump it at the axle like I did it makes it more difficult to fit a muffler up there. I've got plenty of clearance, but I dont have enough to be able to drop the car.
Old Oct 23, 2009 | 07:34 AM
remltr's Avatar
I got some Hedman 3" s-bends today. PS fits like a dream, DS will need to be fitted. I also ordered the Summit x-pipe kit and a set of 3" glass packs. Hope it's gonna work. If it does, I'll try to get some pics up.
Old Oct 23, 2009 | 08:30 AM
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
This sounds like what I am going to have to run. I would like to see some pictures. I guess these headers clear the slave on the T56?
I will need something that flows....I am going to build a AFR headed 400.
Looks like I will be making my own crossmember.
Old Oct 23, 2009 | 01:33 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Im running a very simlar combo to that except Im using Hooker 2210 longtubes. Im using a Skulte xmember, Spohn adj torque arm, aluminum D/S, and Eibach pro-kit springs. Here's a link to my thread:
https://www.thirdgen.org/forums/exha...0s-t-56-a.html
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
