Backfire
Old Nov 6, 2009 | 08:26 AM
VintageStefurak's Avatar
Backfire
My Camaro backfires when I turn the engine off?? What would be the most logical explanation for this event?
The car has an Edelbrock 750 cfm carburetor which I just rebuilt. But the backfiring occurred pre and post rebuild. The idle rpm is at high of about 3500. Is the backfire due to the excess fuel in the engine/intake manifold?
Or is it mainly the exhaust system?
Thanks in advance.
Old Nov 6, 2009 | 11:16 AM
85z/28's Avatar
Car: 85 z28
Engine: 355 SBC
Transmission: 700R4 w/ shift kit & Corvette Servo
Axle/Gears: 3.08
Re: Backfire
I also had this problem occur pre rebuild with my 85 z28 carb, I had a timing problem which would consequently make my carb backfire and attempt to stay running everytime i went to turn it off.
Old Nov 6, 2009 | 11:40 AM
Z28 ENTHUSIAST's Avatar
Car: 91 Camaro Z28
Engine: 305 5.0 TPI
Transmission: 700R4 Automatic
Axle/Gears: IDK. Whatever stock is
Re: Backfire
sorry I dont mean to steal the thread
I too have a backfire problem with my 91 z28 305TPI
my backfiring accurs when am crusing on the freeway and all of sudden let off the accelerator pedal. Sounds like a shot gun going off! am affraid to drive it now...
has anyone had a similar problem?
Old Nov 8, 2009 | 08:22 AM
redtruck18's Avatar
Car: 1987 RS Camaro
Engine: 305 V8 (Carb)
Re: Backfire
Im having the some problem right now with my 87 RS, the carb is a BRAND NEW eddelbrock 650... im not 100% sure if its timing light or not, but im starting to think its carbon buildup. Id to know what you set your timing at to solve the problem. thanks
Old Nov 8, 2009 | 08:30 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: Backfire
I had the same problem with my car at night people have said that it shoots out some prtty mean looking flames when i let outta the throttle. It would be everytime that it sounded like a shot gun though. My issue was the timing is way off. I have parked the car since then and I am converting to carburated so I havent had a chance to see if it still does it or not. One thing you can do is set the car to top dead center and work from there.
Old Nov 8, 2009 | 08:33 AM
Axle/Gears: stock
Re: Backfire
Hey Redtruck18 have you tried runnins some fuel additives like sea foam through it just so it will clean up any buildup you may have goin on, you may see if that help you out at all
Old Nov 8, 2009 | 12:11 PM
redtruck18's Avatar
Car: 1987 RS Camaro
Re: Backfire
No, not yet, but i plan on running some "power tune" through it. (Power Tune is made by a company called Mercury Marine, its designed to remove carbon from inboard boat engines, the basic idea is to spray it in the carb while keeping the engine running, empty at least half the can, let the engine die... come back a few hours later, and SMOKE THE NEIGHBORHOOD... im talking all the carbon in the world blowing out the back end, carbon: goodby) Im pretty sure the timing is just about dead on, maybe off by half a degree either way... but if power tune doesnt help, im gonna play with timing more...
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
