New Single Exhaust Set Up Help!!!
Old Jan 7, 2010 | 07:41 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
I have a 2.5 in. true duel set up on my car. one pipe for each side, no x pipe or anything just two mufflers. with hedman long tubes.
i am thinking i was switch to single soon bcuz of the fact of the ground clearance.
so i was wondering how big should the piping be for a single set up, plus i want it to sound tough as well.
thanx for your help.
Old Jan 7, 2010 | 11:26 PM
antsZRS's Avatar
Engine: 350 SBC
Re: New Single Exhaust Set Up Help!!!
anybody? plz?
Old Jan 8, 2010 | 12:14 AM
kerplunk318's Avatar
If your running a pretty tame setup a 3.0" single should be good.
Old Jan 9, 2010 | 06:11 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well first you've gotta tell us your new combo, i know you built the motor so we need specs b4 we can help you with exhaust size. i'd go with a 3.5" minimum if you have a serious motor, i'm upgrading to a 4" myself so i NEVER have to deal with exhaust again, you cant really over exhaust your car anyways so go big!
Old Jan 10, 2010 | 01:08 PM
antsZRS's Avatar
Engine: 350 SBC
okay sorry guys. had a long cold week!
so far the motor has:
bored .40
new eagle crank
sealed power rods and pistons i think 10.25:1 or something like that
lunati voodoo .504/.525 lift cam w/ 110 LSA
built heads 2.02/1.60 manley valves. i dont know what cc they are but the are decked alot! im almost in the valve.
edlelbrock RPM air gap intake
and planning on holley carb.
MSD
Old Jan 10, 2010 | 04:52 PM
85z/28's Avatar
Car: 85 z28
Engine: 355 SBC
Transmission: 700R4 w/ shift kit & Corvette Servo
Axle/Gears: 3.08
In all honesty i would just use a single 3" system, your cheapest way to go is to buy a catback, I have flowmaster, but from what I have heard magnaflow is the best buy with the sound quality, build, and price.
Old Jan 10, 2010 | 05:34 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i'd run 2.5" or 2.75" pipes that y into a 3" or 3.5" pipe, and either dump it at the axle with a bullet muffler (borla xr-1!?), or run it over the axle into a muffler of your choice. the over axle part is where you will spend the most money, the muffler shop across from the discount tire in kemah is cheap if you just want to get it done, his work is ok but its not mandrel bent
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
gta power
Aug 13, 2015 06:15 AM
