Achieving better Y-Pipe Clearance
Old Jan 14, 2010 | 08:04 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Delete
Old Jan 16, 2010 | 04:07 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Achieving better Y-Pipe Clearance
Bump, I know someone else has had to of dealt with this issue.
Old Jan 16, 2010 | 06:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
poly inserts for the stock clambshell will raise the engine.
Old Jan 16, 2010 | 06:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by KYLE87
Its extremely low
What's extremely low?
JamesC
Old Jan 16, 2010 | 06:50 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
N/A
Old Jan 20, 2010 | 07:54 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Jan 20, 2010 | 08:39 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
ive got this same problem but with my cat
i can literally stick my forearm inbetween the the car and the pipe
ive seriously considered putting a length of 2X8 on a jack and trying to bend it up higher
is this a reasonable thing to do?
what if i had a blowtorch to heat the metal first?
Old Jan 20, 2010 | 09:00 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
A Good muffler shop can do that for you.
this is how you would do it at Home..
get the car on Jack stands up Hi enof to get under and move.(you)
you will need a good jack.. and a thin sheet of alum
(tween pipe & car bottom) check see space..
put jack on Pipe.. run jack up till you see pipe pushing up.
start to heat pipe till red, apply a bit more force up and let cool.
check see space... is it moved up more.? repeat till done.
NOTE: pre loading the pipe with presher gives you a 2nd set of hands.
when the pipe is soft enof To MOVE..it will tweek upward from the presher. saving you the time to see if it is time to push it..
this can be done in more then one place...
this 3" cat back runs close to the bottom pan of the car.
other parts AKA lift bars sit lower.. (pips are tuck up nice and neet)
Y Pipe sitting up nice and High.. from Y cat back sits on yop of cross member up over rear.. and out. factry styl..
Old Jan 23, 2010 | 09:29 AM
skinny z's Avatar
I modified the cross member to get a little more ground clearence.
Attached Thumbnails Achieving better Y-Pipe Clearance-100_1899.jpg   Achieving better Y-Pipe Clearance-100_1897.1.jpg   Achieving better Y-Pipe Clearance-100_1948.1.jpg
pontiacdog
Mar 7, 2014 10:31 AM
lil_grover
Dec 8, 2005 01:01 PM
Scorpner
Oct 3, 2005 10:57 AM
89 RS vortec 35
Jan 25, 2003 05:00 PM
330hp_91RS
Nov 9, 2002 10:03 AM
